Misc jeep drivetrain
All of this is coming from a 86' CJ-7
4.2l 258 straight six......has alumn. 4wd hardware valve cover and webber carb, comes complete from flywheel to fan with all acessories.........$200 bucks
T-5 5 speed trans and dana 300 t-case......has the coarse spline input and bell housing needed for I-6 and V-8, also it has the sloppy shifter syndrome like they all do......transmission is ok...........$250 takes both
Dana 30 wide track front complete from hub to hub, tie rods and all......superwinch hubs and 3.31 gears
Dana 44 wide track complete from drum to drum.....open diff i believe and also has 3.31 gears.... $250 for front and rear ends
Driveshafts are for sale too.....$20 per shaft w/good joints
I will wheel and deal and if you need any other items just let me know!!! All is for local pick-up only!!!!
What's up doc? Why you parting out the CJ??
Looking for a front drive shaft though ... :wink:
Have a brake booster you don't need for a mid-80's CJ?
Have good front shaft but no booster......traded a edelbrock carb for the whole jeep....decent frame and beat up dented yj tub.....project that never finished and had to be sacrificed for another project.
