Nicely Built AMC 360 $2000 obo, Norfolk Va 23503
I have a nicely built AMC 360 for sale... Below are some of the parts used... this motor has less than 300 miles on it. The reason for the sale is simple... It's to support the 496 stroker build :!:
AMC 360 bored .030" (4.110") with brass freeze plugs installed, blocks been decked (Can't recall how much) #-o
Edelbrock Carb (Keeping the Holley Carb) :oops:
Edelbrock Performer Intake
Internal Oiling Mod
Heads Milled and Machined, new brass freeze plugs and positive valve seals
AMC Legend Valve Covers (Bulltear special :t: )
Harland Sharp 1.7:1 Roller Rockers
Comp Cams Magnum Chromoly One piece .080" Wall Pushrods
Ross 10:1 Forged Race Pistons
Chromoly Rings
Scat Forged H-Beam Rods with ARP bolts
Clevite Bearings
Crank turned 10/10
Comp Cams 280H Magnum Cam and Lifters
Comp Cams Magnum Timing Set
3 angle vlalve job
10* super locks etc
1 5/8" to 3" Dynomax headers
3" purple hornies (Header mufflers)
Stock manifolds go with it
7.5 quart oil pan (Bulltear Special :!: )
New Water pump
160* thermostat
HEI Distributor
Cardone Distributor with msd Cap adapt
Pro Comp 6al Ignition Module (Keeping the MSD) :oops:
High Energy 50,000 volt coil with aluminum guard
8.5mm wires
Rohl head gaskets
I will have some pics of the motor as well as a video of it idling and me smoking these 35" swampers. 8)
