here is a pic of the specs for a 8601 summit/super stock camshaft for AMC V8's it is a mid-high range cam..........
http://www.imgbay.com/sites/jeepsr4e...%20cam0001.jpg[/url]
Here is the 8600
http://www.imgbay.com/sites/jeepsr4e...it86000002.jpg
moved this to the top for better viewing
which one would be better for a 360 in a cherokee fullsize with a edelbrock intake and 650 carb? i'm thinking the second one
8600 would be the cam of choice if you went with summit
thanks :?
since I got the engine top tore down anyways (replacing manifold and valve cover gaskets and such) I have decided to change cams, maybe improve proformance abit. which cam would you guys recommend I go with. Considering the summit cams' as mentioned above. also considering changing the valve springs, any recommendations on those as well?
Redemption........thats a whole new topic right there
What's the most lift you can use before needing headwork?
