V-8 oil pump diagram
Looking for a parts diagram that will show all parts and gaskets for a '70 amc V-8. I especially need to know the correct gasket/material to be installed on the pressure bypass (copper/paper). Also, looking for feedback on the usual places to look for oil leaks on the rest of the oil pump housing. Thru-bolts possibly?
Are the .002 gaskets still available thru Bulltear?
Is the correct reassembly order on the mid-plate:
Housing and gears, then gasket, then mid-plate, then gasket, then cover?
Have some minor leaks and poor memory, any help would be appreciated so I can tighten thing up.
