8 Attachment(s)
advice needed on new slightly damaged piston
After gathering parts for several years for my 401 build, I finally have gotten started on putting it all together. Long story short, my shop who did the machine work installed one of the cam bearings slightly crooked (tried the new engle cam and the original, neither of which would slide all the way in). This resulted in me having to take back out the Pistons and crankshaft from the block and take it back to the machine shop to have them install another set of bulltear cam shaft bearings. In the process of the tear down, I somehow managed to knock one of my Pistons off of my work bench onto the concrete of my shop floor. There is some slight damage to the top edge of the piston. My question is, at this point, what are my options? Polish/buff down the burrs on the piston and run it? Replace the Piston with another bulltear unit? Will the small pits cause any issues? Etc?
This is only engine build number six for me so I'm hoping to get some advice from anyone with a little more knowledge/experience than me on what to do at this point. Still pissed at myself for knocking it off the work bench; not even sure how I managed to do it. The pictures of the damage should be attached. Thanks for the help!
