Originally Posted by 82Waggy
Hate to be the one that always seems to disagree, but unless you are planning on bumping your compression up a bit from stock and/or adding taller gears I would look for a shorter duration cam than the Summit 8600.
Does'nt sound like you are planning for more than 4-4500rpm in a daily driver. Look for an LSA of 112 and a .050 intake duration closer to 204-207 in order to help build cylinder pressure and torque. Intake valve lift much in excess of .450 in stock heads for your application will gain you next to nothing. A Crower 258H Baja Beast or an Engle 35018H comes to mind for good power with stock compression from off idle to 4-4500rpm.
