360 with oil out of dipstick tube
Ran the jeep out on the road for the first time yesterday, after a couple of block down the road notice smoking from under the hood get out and check and see oil pumping out of the dipstick tube onto the exhaust manifold. It was a pretty good stream pumping out not just dripping. The is the first time I have really run the engine on the street. I am assuming I am getting pressurization in the crank case. I unhooked the EGR line which seemed to help at idle but when driving it still pumping out. What could be the cause? Blow by on one of the cylinders? how do I check, just a simple compression test. I have a plug on the oil fill tube cap nipple could this have anything to do with it? All hoses and the PCV valve are new, the EGR valve is old.
