1986 CJ-7 Dana 44 & 30 Warn Wide Track Axles
I have a set of axles off a 1986 Jeep CJ-7
Front axle:
4.10 gears
Detroit locker (recent)
Warn big joint snap ring chromo axles
Warn internal hub conversion
Warn lock-outs
New brake rotors
New brake pads
Wheel bearings checked and repacked
Front is still spring under, weld pads to top if you want spring over.
Rear axle:
ONE YEAR ONLY Dana 44 CJ Wide Track!
4.10 gears
Detroit locker
Warn Full Float Chromo axles
Warn Drive flanges
Warn lock-outs (extra)
Disc brakes
Custom 1/2" thick axle tubes (stock width)
Traction bar (like Sam's Offroad HD)
Rear is spring over, weld pads to bottom if you want spring under.
I have about $4,500 in the pair.
$2,250 or offer plus shipping
Would ship nation wide
I'm located near Des Moines, Iowa
E-mail: oneton401@msn.com
Edit:
Back for sale as a set. Previous buyer didn't come through even after I packed and checked all bearings and replaced front brakes and rotors. I also checked all ring and pinions for missing teeth or any problems. Axles all rotate freely, so there are no bent housings that can be found either.
I had these on a 1983 CJ-7 with spring over rear and spring under front. Just never got around to the high steer.
I am not currently going to part out.
Extra parts in pictures are going with, including extra spare axles, yokes, C clips, hubs, drag link, rod end and front traction bar bushing etc.
http://i44.photobucket.com/albums/f3...5Axles0001.jpg
http://i44.photobucket.com/albums/f3...5Axles0002.jpg
http://i44.photobucket.com/albums/f3...5Axles0009.jpg
http://i44.photobucket.com/albums/f3...5Axles0008.jpg
http://i44.photobucket.com/albums/f3...5Axles0007.jpg
http://i44.photobucket.com/albums/f3...5Axles0006.jpg
http://i44.photobucket.com/albums/f3...5Axles0005.jpg
http://i44.photobucket.com/albums/f3...5Axles0004.jpg
http://i44.photobucket.com/albums/f3...5Axles0003.jpg
