Need a pair of motor mounts that bolt to the block for a small AMC.
thanks
thanks
Did you check NAPA? they sometimes they have things that you wouldn't think they would. If you can't find them there I may have a set if they are the same as for a jeep. Where are you at?
Good luck
I need the motor mount plates. the Steel brackets not the rubber mounts. I'm located in St. Paul, MN. Thanks.
Are they the ones that go between the rubber mounts and the frame? if so which vehicle?
they are the brackets that bolt to the block between the block and the rubber mounts. they are the same for all of the small cars with V8's. thanks
Define "Small AMC" a 4, 6 or 8 ?Quote:
Originally Posted by RWC78
Engine is a V8, Car is an Spirit.
the mounts he is looking foe almost look like cj block mounts but a little shorter
Gotcha :oops: ! Sorry can't help with those.Quote:
Originally Posted by fuzz401
Pat
