Bulltear HEI Plug Wire Set
Well, It looks as if I will miss out on the special price for Bulltear's HEI dizzy before it ends 12/31.
My question today, when I do order an HEI distributor, when makes the best premade, plug in and go wire set.
When I did the TFI on my J20, I bought two set of wires.
The first set did not have a long enough wire to each the #8 plug.
The second set, I had to over the passenger valve cover to get to both the #7 and the #8, instead of routing them neatly along the bottom of the valve pan, like I did the other 6 six wires.
I've had really crappy luck with the cut, crimp and make your own plug wires.
If DIY is the only way to go, then what brand/part numbers work best?
