Does anyone out there know what parts interchange between a 1977 DJ5F postal jeep and a normal 1977 CJ5?Body,mechanical,electrical,lighting,chassis,et c
I'm not sure after 1975, up till then, the frames were identical, and a lot of parts swapped. Given that most DJs had full bodies (top not removable, except with a sawzall :shock: ) , were RHD and 2WD, a lot of parts won't swap. I would think that when they changed the CJ frame in 1976, they changed it on the DJ also. I'd just take some rough frame measurements. If the frames are the same, some parts will swap.
