Camshaft Question for AMC 360 Engine
Hi guys,
I'm just about to overtake my jeep CJ-7 360 AMC engine. He is bored to 390cui and has Ross Pistons, Offenhauser 360 ° dual port manifold, installed 750 2bbl Holley carburetor and MSD distributor with 6AL module. The transmission is a T-18 with Centerforce dual friction clutch and the Dana 20 transfer gear and the AMC20 rear axle. Tires I drive 33x12,5x15 AT's and ride mostly street.
Now comes my question, which camshaft is optimal according to your opinion, if I want to drive a speed range from 800 rpm to 5000 revolutions. The jeep is to burn the strip .... I had a cam installed I chose wrong (CompCam Magnum 292h speed range 2000-6500 rpm) will replace this !!
What opinion did you ??
Greetings from Germany
P. S. : Bulltear Matched Gears for Dizzy are the best !!!!!!!!!!!
