Dont quote me on this, but intuition tells me that the VTEC system and the DOHC engines that have the variable valve timing, will do something to "phase" the cams - one exhaust and one intake.
This is simliar to the idea here, with the exception that not only could we alter the lobe centerlines, but we could also make adjustments to the lift and thus duration as well.
The two may be alike, but I know 0% about the specifics VTECH, so if this appears that I'm copying them, then it is by mere coincidence only, for I have had this idea for a long time, but never knew anyone who might could make it come to life.
MC to answer your questions:
I have heard and done some primitive research on the Rhodes lifters. But where we differ is in the field of adjustability and reliability. With Rhodes I would be interested to hear from some long term test, to see what they will hold up to. After 10,000 miles, after 20,000 or 50,000 and some dirt, what happens?
I would like to use Rhodes, so don’t take it that I’m slamming them. But I would like to learn more.
With regard to the construction of the pressure hoses….my first thought would be for rigid and smooth bend hoses. But then Vibration? Ok so lets go with hydraulic lines, Northern Hydraulics – I think they are now known as Northern Tool and Equip. – Has lengths of 14” to whatever length. Their lines are rated for upwards of 10,000 psi and 20,000 psi. Granted we’ll probably not see these pressures, so perhaps some easier to manage Stainless steel lines would be preferred. And then an idea of a “Fuel Rail Like” design… with a rigid body, and only 1 hose per rail, would be the least moving parts, perhaps least susceptible to vibration. And then finally the options to eliminate vibration are to created whatever network of hoses or rails you want, and then make a tray of epoxy that would hold everything in place, much like electronics.
The options are many, which one suits us best is yet to be determined.
Why run a Camshaft….. A really good thought not to run one, but the reliability of timing becomes and issue, and then the “what if” this breaks approach comes in. With a cam and adjustable lifters you would at least have a fall back, to where if the lifters went to Zero pressure, the cam would take over – albeit not as well – but it would still cycle the valves. And then the timing of the valves, keeping them all in unison would become an issue if we were relying on pressure to actuate them 36 times a second @ 3000 rpm.
And then with regard to a pump…Power steering pumps develop some high pressures, and they are belt driven. So perhaps another belt routing idea looped around another pulley that would be the auxiliary oil pump. - I really don’t know, but that’s still in the brainstorming section –
My apologizes for the length,
But I am eager to hear responses, thoughts, and critiques.
Mike
In reguards to the Rhodes lifters they work great in theory BUT when you have a fluctuation of oil volume to the lifter they dont work so we see a progressive failing of the lifters pnuematic pressures. The idea of having a hydralic line to each lifter CAN be done, but we need to examine it a little closer.......
1. Is the amount gained worth the amount used?
2. Can we incorporate the dwell of the piston at TDC
3. Where is our biggest advantage gained
4. What about servicable parts
6. A pressure relief would need to be made
Help me understand what you mean when you say dwell of the piston? And what you are thinking of? I'll be the first to admit that I'm ignorant, and it seems the more I learn, the more I realize that I dont have a clue.
Oh well, ask more questions.
Amount gained.... I assume you mean in power created vs power taken to turn the pump. I wouldn't think it would take more than 10 hp to do the pump, and creat phenominal gains - across a broader RPM range.
We're still in Prototype mode
I'm eager to hear of your knowledge, and what you have to say...... although I am wondering why the rest of the board is remaining quiet on this one...... :-|
Look foward to your input MC
We need to get you a CAD system!
The dwell is the amount of time proportional to the rotation of the cranl that the piston sits at the top of the stroke.
I guess in my personal experience the hydralic line dont last forever BUT we would need to talk about the pressure we need here, lets say your valve springs are rated to a spring rate of 250-300 lbs (common double valve spring) how much volumetric pressure would we need without overkill
It raises alot of questions....hmmmmm
I have access to and have been trained in a program called Pro/E = ProEngineer. Only problem is, it's for educational use only. So if I were to design something, I could save it, but it will not convert to a professional file program. The best that I could do would be to take desk top pics, and/or send you print outs.
I have a good conceptual idea of things in a spatial orientation. Mathematically I can easily see how the piston moves at its maximum velocity and travel when the connecting rod is nearly perpendicular to the crank. As the piston and rod travel in the combustion chamber I can easily see how this motion slows down, ultimately reaching a zero point. But to calculate this, we would need to take a derivative with respect to piston movement, of the crank. This would tell us the EXACT position where the piston reaches TDC – I know duh – but then pick your allowable window of negligible movement, and that would become your dwell would it not?
I have access to Auto CAD, and ProE….. Benefits of being a college student ….. I’m only 21…a business student at UNC-Charlotte but with a passion for Mechanical Engineering, and AMC.
-Best regards,
Mike
MC,
What would you like to be seen on CAD, or Pro/E = a 3-D rendering model.
Model of the lifter?
Lines?
or Pump Location?
And if I can get an idea on paper, in design form, could you manufacturer "test" lifters for me, or who would you suggest going to to make a Prototype?
You draw it send it to me and we will discuss going forward
