Hey Mud, I found these on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33593
Thought you might be interested,
Jack
Jack
Thanks Jack, already have them installed. THESE are what I'm looking for but DANG they are expensive!!!
edit-mudrat: they corrected the pricing on the page from 29.90 to 2.99 so I ordered 10 of them :-)
:t:
jack- 8) :mrgreen:
OK - http://smiley.onegreatguy.net/update.gif
Got the outboard perches done and in, started with the drag link and tie-rods. May have a problem.
Got the new heims on the rods and the rods on the Jeep. Used the new conical offset spacers. Concerned they are going to allow to much stress on the bolt though??
http://members.cox.net/mudrat/85%20CJ/New%20Heims.JPG
And - the Drag-link
http://members.cox.net/mudrat/85%20CJ/Drag_link.JPG
Looks like a 2" drop arm would do the trick. The DRAG (hehehe) is that the pitman arm needs to have a 3/4" hole to fit the heim joint.
Anybody have any suggestions on where to get one that fits the standard GM sector shaft but has the 3/4 hold in it for the drag link??
ALSO, I'm going to have to add some angled shims to the front axle. With the spring reverse and the length of the shackle, the drive shaft is at 15 deg and the axle is only at 10. Basically the axle is now paralell with the ground instead of turned up to meet the transfer case :smile:
MC ... got any 5-6 degree 304 or 316 shims laying arround :?
Mudrat :idea:
nope not at this moment
Pat, Try contacting Sam of Sam's Off Road in OK (www.samsoffroad.com). He has someone that makes him heavy duty steering arms.
http://www.sams4x4store.com/images/C...PittmanArm.jpg
He might be able to help you out in someway. Real cool guy - has a killer CJ7 on 39 boggers with lots of HP. :t:
I still say go with the one inch spacer instead of the cones - looks like it would be a lot stronger. I think the bolts will fine most of the time, but would suck if one broke on the interstate! :shock:
Or you might be able to fab a bar up on top to reinforce it. Maybe get some longer threaded rods (dang it, forgot the correct name) that hold the arm to the knuckle. Just another idea. I still say that the spacer is the way to go.
Oh well, that's just my .02. I am just jealous that your shizn!t is almost done and mines still in tons of pieces! :smile:
Jack
Thanks Jack, 'Sams' must really like those pittmans - at $120 each!
And I HAVE the spacers, the offset cones are for articulation of the Heim joint. Agree it would suck ANYTIME if they broke, that's why I went 3/4" grade 8 bolt (they were 5/8's), over 30K lbs//ft of clamping and 120K ft//lbs of shear strength for a Jeep that may top out at 3K pounds loaded w/ pax :-)
By the way that's the drag link between the pittman and the steering arm on the knuckle. It's a tierod between knuckles :wink:
