Both CompCams & Crane make solid roller lifters for AMC. Crane also makes hydraulic roller lifters & cams, but aren't in the catalog(special order). The AMC lifter diameter is .904, but a Chrysler lifter is different. The oil feed hole/groove is in a different location. It would probably work in a stock engine, but with a higher lift cam, oiling to the top end may be compromised. Also, while the ratio is the same, a 1.6 SBC roller rocker is NOT the same as one actually made for an AMC. The ratio isn't the problem, it's the distance from the fulcrum to the valve tip. The SBC rocker is shorter. They'll move the valves, but the geometry is WAY off. Roller cam set-up are very expensive, & bring up a bunch of new problems....mainly a way to control cam walk. Not impossible to do, just more work to add to the project.
roller rockers
crower makes them in stainless steel for 3\8 or 7\16 studs too
hey Fuzz i meant lifters..LOL
I beleave they make roller lifters too
I really need like a roller rosettire beer holder for days like today........LOL
roller lifters
Crane is the only company currently making roller HYDRAULIC lifters for an AMC - more may follow if they sell enough. I just ordered a set they aren't cheap $650!
JUDAS PRIEST 650............WHEW
1. wish i had a million dollars
2. if i did i would buy every mod for a amc v8
3. All performance items i would personally install
4. The engine probly wouldnt start
5. i would be out of money
LOL :cry:
HEY MAN, LOOK ON THE BRIGHT SIDE-
oh wait, never mind
