Nobody mentioned when you put in back in do you weld in the burn out spots?
Absolutely...we use a Jig when we do it here
I have a couple of questions.
What type of weld process did you use being it's cast to steel?
Is there any how to shorten the axle info?
You can send your shaft to Moser or and of the axle companies and have it cut down. You can use industry std. mild steel wire on the tube to housing as the materials are VERY close to each other.
I would love to have that Info., it is all red "x"'s though.
