Awsome jeep and its on propane :t: I like that will be doing the same i have all the stuff was going to put it on my wrangler but now im thinkin about puttin it on my 64 gladiator :t:
Haven't started it yet, but thought I'd share a pic of setup. Late 70's 360, stock exh manifolds, Edelbrock intake, gotpropane kit. All that's left is getting the oil pump primed. The tank rings are in the back in place of the seat. I'm going to drop the floor about four inches in the new tub and put a rack above them. There is nothing mounted on the fenders, it's all on the firewall.
http://memimage.cardomain.net/member...10_32_full.jpg
http://memimage.cardomain.net/member...2788310_34.jpg
Did a little wheeling this weekend. The drop is about 8'. :lo1l: The propane didn't skip a beat. Do THAT with a carb.
http://www.youtube.com/watch?v=Y1EKQjPBMrc
Not with a carb. I learned that my Holley would stall before the Jeep reached it's roll point. The second trip out with my EFI, I forgot that I didn't have that safety valve, had to reach up and turn off the key because it was still running UPSIDE DOWN #-o .
Dan did you do up those hummer wheels?
Otter Whaley did them.Quote:
The center holes were milled, and the had a little milling done to clear the bolts. The kit is Marsh Racing.
Thats a nice way to go!
Thought I'd bump this.
After three full years of wheeling with the gotpropane.com kit, I have ZERO complaints and zero failures on my system. I won't call running out of propane an error of the system. :?: That *might* be on the driver. 111!!!
If you are at all thinking of propane on a 360, this is definitely the way to go. I'll be racing this year in the RCRocs series, so we'll get a real good idea about propane on an AMC.
