Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2962 Current Set Up
d30 front w/4.88 and loc-rite
d44 rear, offset rear, w/4.88 and powertrac, custom full float axles
t18 tranny
d18 transfer with twin stick, pill removed for both hi & lo 2wd
3" rancho lift with shackle reversal
8000# warn winch
full cage and body armor
33 x 12.5 swampers on chrome spokes
jeepster front clip
Check out my web page for pictures and details.
09-23-2004, 06:57 PM
rollen dean montoya
well not much to tell yet but here goes
1983 amc eagle(commonly known as jeep eagle)
203000 mile 258 I-6 carter bbd carb
k/n air filter
bfg a/t 215/75-15
amc 30 front diff(still independant front end for ride)
amc 20 rear
monroe heavy duty coil over shocks
stock front shocks
stock rims
the factory hub caps with 4x4 on the spinners(need to r/r 2)
998auto trans
the stuff that will be done soon
new rims
np229 t-case
better armor for the fuel tank
bigger fuel tank
new 258 I-6
metal valve cover
solid front axle
roof rack with dig out gear and highjack
jerrycan holders for 2 5gal cans of gas
108" C.B. antenna
cobra 148 cb tweeked to max wattage
full size spare
a killer sound system for my listening pleasure
there ya are in a nutshell.
later, rollen :lo1l:
09-24-2004, 06:04 PM
You have hub caps??? :shock:
Mudrat :mrgreen:
09-27-2004, 08:35 PM
rollen dean montoya
yes mudrat i still have the stock rims. as i freeup funds i might get new rims or i just might keep the stock ones and find the 2 hubcaps i need.
10-01-2004, 08:40 PM
rollen dean montoya
found an np-229 t-case. it is at atransman's shop. he does real good work
we discussed what the price would be. he will let me know . now for the 2
hubcaps to replace the ones i broke #-o
11-09-2004, 03:26 PM
eight
81 CJ8.
dead 258 (3rd one)
dodge np435
d300 clocked and twin sticked
chevy d44hd front
ford d60 rear
SOA on bastardized YJ/CJ springs
36" hummer tires, they suck.
Onboard welder, air, MFH, half crazy pollock, etc.
Soon to get AMC V8.
Got 38s, need bigger front axle to run them.
1980 Cj-7
Built AMC 370: Port and polished, 60 over, balanced, harland sharp roller rockers, comp 270 cam, holley truck avenger 670cfm, edelbrock intake, edelbrock headers, aluminum water pump, MSD distributer, MSD ignition, TFI upgrade and a ton more stuff on the engine.
Dana 44s front and rear. Chromoly shafts front and rear.
sprung under with 4" skyjacker rear YJ springs front and rear. Drop hanger brackets with widened spring perches, 2" body lift for about 10"s lift total.
TJ Zenon fender flares.
NP 435 tranny with 4.33 Atlas Transfer Case.
35x16x15 boggers.
Full cage, custom front bumper with 8274 on front.
Hyper shackles in the rear with a custom front shackle reversal.
I guess that 's the main stuff. :lo1l:
11-12-2004, 10:00 AM
pyagid
EIGHT and IBJEEPIN Both very nice set ups :t: I cant wait till i have mine back on the trial
11-12-2004, 10:35 PM
mulescj8
current set ups
Well my current set up is 4 jack stands-lol.........I just sold my daynatrac dana 60s,getting ready to build a new set of Rockcrusher dana 60s,both High Pinions,out boarding the front springs and going to RE extreme duty YJ springs or waggy springs,FI 258 will be coming out this winter and a FI 401 will take it's place,keeping the 4to1 transfercase and the NV4500 tranny.............also going to build a new dash and a set of tube fenders that will tie to the cage,frame and front bumper-JC :t:
11-13-2004, 02:35 PM
Mules - where in East Tenn are you? Little borther is up there somewhere too. He's about 2 -2.5 hours from Tellico.
