Installed SS extended brake hose
http://www.street2mud.com/albums/M17...2229.sized.jpg
http://www.street2mud.com/albums/M17...2230.sized.jpg
Installed factory bump stops until I get around to newer ones
http://www.street2mud.com/albums/M17...2231.sized.jpg
Drilling hole for manual choke installation (had one in the tool box since 2005)
http://www.street2mud.com/albums/M17...2233.sized.jpg
Location of manual choke bracket
http://www.street2mud.com/albums/M17...2234.sized.jpg
Manual choke bracket installed
http://www.street2mud.com/albums/M17...2236.sized.jpg
Slide cable/sheath through the bracket and lock it down w/the lock nut
http://www.street2mud.com/albums/M17...2237.sized.jpg
Slide choke cable through the drilled hole
http://www.street2mud.com/albums/M17...2238.sized.jpg
Choke cable dead ended
http://www.street2mud.com/albums/M17...2239.sized.jpg
http://www.street2mud.com/albums/M17...2240.sized.jpg
Set desired length for sheath then cut (remove the cable from inside first)
http://www.street2mud.com/albums/M17...2241.sized.jpg
http://www.street2mud.com/albums/M17...2242.sized.jpg
Slide cable back through the sheath
http://www.street2mud.com/albums/M17...2243.sized.jpg
Open the choke to set the cable, pull tight
http://www.street2mud.com/albums/M17...2244.sized.jpg
Operate choke
http://www.street2mud.com/albums/M17...2245.sized.jpg
Received oil back flow block off plate from my friend @ Bulltear
http://www.street2mud.com/albums/M17...2247.sized.jpg
