It also appears like your Mag-Lok plate is getting pulled sideways from the lead coming off the bracket. This may just be optical in your picture but may contribute to your angled cuts.
N0000 (Filename: SBCMMPlate.tap)
N0010 (Post processor: MP1000-THC.scpost)
N0020 (Date: 5/6/2012)
N0030 G20 (Units: Inches)
N0040 G53 G90 G40
N0050 F1
N0060 (Part: SBCMMPlate)
N0070 (Process: Inside Offset, holes, T3: TD82 .25" 40a)
N0080 M06 T3 F30 (TD82 .25" 40a)
N0090 G00 Z0.5000
N0100 X2.5431 Y1.0066
N0110 Z0.1600
N0120 G28.1 Z0.12
N0130 G92 Z0.0
N0140 G00 Z0.0520
N0150 G92 Z0.0
N0160 G00 Z0.1600
N0170 M03
N0180 G04 P1.5
N0190 G03 X2.5134 Y0.9553 Z0.1000 I0.0815 J-0.0815 F2.5
N0200 X2.5431 Y0.8437 I0.1112 J-0.0301 F30.0
N0210 I0.0000 J0.1500
N0220 Y1.0066 I-0.0815 J0.0815
N0230 M05
N0240 G04 P0.5
N0250 G00 Z0.5000
N0260 X0.7839 Y4.0989
N0270 Z0.1600
N0280 G28.1 Z0.12
N0290 G92 Z0.0
N0300 G00 Z0.0520
N0310 G92 Z0.0
N0320 G00 Z0.1600
N0330 M03
N0340 G04 P1.5
N0350 G03 X0.8353 Y4.0691 Z0.1000 I0.0815 J0.0815 F2.5
N0360 X0.9469 Y4.0989 I0.0301 J0.1112 F30.0
N0370 I-0.1500 J0.0000
N0380 X0.7839 I-0.0815 J-0.0815
N0390 M05
N0400 G04 P0.5
N0410 G00 Z0.5000
N0420 X4.2628 Y4.1065
N0430 Z0.1600
N0440 G28.1 Z0.12
N0450 G92 Z0.0
N0460 G00 Z0.0520
N0470 G92 Z0.0
N0480 G00 Z0.1600
N0490 M03
N0500 G04 P1.5
N0510 G03 X4.3142 Y4.0768 Z0.1000 I0.0815 J0.0815 F2.5
N0520 X4.4257 Y4.1065 I0.0301 J0.1112 F30.0
N0530 I-0.1500 J0.0000
N0540 X4.2628 I-0.0815 J-0.0815
N0550 (Process: Outside Offset, 0, T3: TD82 .25" 40a)
N0560 M05
N0570 G04 P0.5
N0580 G00 Z0.5000
N0590 X2.6624 Y0.2416
N0600 Z0.1600
N0610 G28.1 Z0.12
N0620 G92 Z0.0
N0630 G00 Z0.0520
N0640 G92 Z0.0
N0650 G00 Z0.1600
N0660 M03
N0670 G04 P1.5
N0680 G03 X2.6469 Y0.2989 Z0.1000 I-0.1152 J-0.0006 F2.5
N0690 X2.5466 Y0.3562 I-0.0996 J-0.0579 F30.0
N0700 G02 X1.9709 Y0.7126 I-0.0035 J0.6375
N0710 G01 X0.2252 Y3.8168
N0720 X0.2242 Y3.8187
N0730 G02 X0.7968 Y4.7364 I0.5726 J0.2801
N0740 G01 X4.2757 Y4.7440
N0750 G02 X4.8514 Y3.8326 I-0.0000 J-0.6375
N0760 G01 X4.8503 Y3.8305
N0770 X3.1183 Y0.7188
N0780 G02 X2.5466 Y0.3562 I-0.5752 J0.2749
N0790 (Part: SBCMMPlate[2])
N0800 G03 X2.4320 Y0.2404 I0.0006 J-0.1152
N0810 (Process: Inside Offset, holes, T3: TD82 .25" 40a)
N0820 M05
N0830 G04 P0.5
N0840 G00 Z0.5000
N0850 X0.8107 Y5.4480
N0860 Z0.1600
N0870 G28.1 Z0.12
N0880 G92 Z0.0
N0890 G00 Z0.0520
N0900 G92 Z0.0
N0910 G00 Z0.1600
N0920 M03
N0930 G04 P1.5
N0940 G03 X0.7514 Y5.4491 Z0.1000 I-0.0318 J-0.1107 F2.5
N0950 X0.6682 Y5.3690 I0.0276 J-0.1119 F30.0
N0960 I0.1312 J0.0727
N0970 X0.8107 Y5.4480 I0.0318 J0.1107
N0980 M05
N0990 G04 P0.5
N1000 G00 Z0.5000
N1010 X2.6624 Y8.4858
N1020 Z0.1600
N1030 G28.1 Z0.12
N1040 G92 Z0.0
N1050 G00 Z0.0520
N1060 G92 Z0.0
N1070 G00 Z0.1600
N1080 M03
N1090 G04 P1.5
N1100 G03 X2.6613 Y8.4264 Z0.1000 I0.1107 J-0.0318 F2.5
N1110 X2.7414 Y8.3433 I0.1119 J0.0276 F30.0
N1120 I-0.0727 J0.1312
N1130 X2.6624 Y8.4858 I-0.1107 J0.0318
N1140 M05
N1150 G04 P0.5
N1160 G00 Z0.5000
N1170 X4.3557 Y5.4468
N1180 Z0.1600
N1190 G28.1 Z0.12
N1200 G92 Z0.0
N1210 G00 Z0.0520
N1220 G92 Z0.0
N1230 G00 Z0.1600
N1240 M03
N1250 G04 P1.5
N1260 G03 X4.3546 Y5.3874 Z0.1000 I0.1107 J-0.0318 F2.5
N1270 X4.4347 Y5.3043 I0.1119 J0.0276 F30.0
N1280 I-0.0727 J0.1312
N1290 X4.3557 Y5.4468 I-0.1107 J0.0318
N1300 (Process: Outside Offset, 0, T3: TD82 .25" 40a)
N1310 M05
N1320 G04 P0.5
N1330 G00 Z0.5000
N1340 X0.1995 Y4.9728
N1350 Z0.1600
N1360 G28.1 Z0.12
N1370 G92 Z0.0
N1380 G00 Z0.0520
N1390 G92 Z0.0
N1400 G00 Z0.1600
N1410 M03
N1420 G04 P1.5
N1430 G03 X0.2420 Y5.0141 Z0.1000 I-0.0564 J0.1004 F2.5
N1440 X0.2436 Y5.1296 I-0.0989 J0.0591 F30.0
N1450 G02 X0.2762 Y5.8059 I0.5559 J0.3121
N1460 G01 X2.1448 Y8.8377
N1470 X2.1460 Y8.8395
N1480 G02 X3.2262 Y8.7836 I0.5226 J-0.3650
N1490 G01 X4.9195 Y5.7445
N1500 G02 X4.4015 Y4.7992 I-0.5576 J-0.3091
N1510 G01 X4.3991 Y4.7991
N1520 X0.8378 Y4.8054
N1530 G02 X0.2436 Y5.1296 I-0.0384 J0.6363
N1540 G03 X0.0867 Y5.1737 I-0.1004 J-0.0564
N1550 M05
N1560 G04 P0.5
N1570 G00 Z0.5000
N1580 X0.0000 Y0.0000
N1590 M05 M30
Checked the wiring and switch. Light on screen for Zhome never came on when wiggling wires. I ran a program and watched the light on the control board to and it never goes out, even though the Z is finding its zero on its own
The torch is angled because I was messing with the Z axis, but it was straight when I was cutting the parts earlier.
Code looks good! When the Z touches the Z home should come on in Mach 3 diagnostics. If the little microswitch got stuck it would raise to your "rapid clearance plane" height set in sheetcam. Then it should do the G28.1 code to Z0.12 and if the switch is stuck, fire from there. It may also try to reference right away if the switch is sticking. Generally these issues are something stupid simple but without being there we will have to go through some steps. Now the switch is ACTIVE LOW disabled so it trips when it looses contact. This means the switch is always on until the travel comes off the switch and it looses contact. This is how it references Z Home and the light will most likely always be on in the control box. Are you using any other inputs on the I/O board? Are you doing anything different than we suggest on that board?
Yes the switch is Active low. When torch touches the table and lifts, the switch is opened, the Zhome light comes on in Mach. The light is also on in the control box.
I hooked a multi-meter up to the switch and am checking continuity on the switch while running a program, and the switch never opens which means it never activates since its Active low.
Tell me if I am doing this wrong.
-Load G code.
-Zero X,Y
-Ref Z off of a material (this value is never consistent) Sometimes it gives me a the value I entered in the post per the DTHC instructions, sometimes its 0, sometimes its a random number. If the number is random, I do it until the number is 0 or the entered value. When I do this I ensure the limit switch is being hit and the Zhome light comes on. I have tried zeroing the Z before and after RefZ, and get same results
-Run program...watch it fuck up. Now I cant even get it to do the first pierce of part with out being to high.
The only other input we are using is X home for the breakaway like you suggest.
We are not doing anything different....we are just trying to learn to walk with this thing!
Matt.....I will be gone all week, but Chris will be calling you this morning.
I am on the phone with Chris
Boy all this trouble seemed to stem from a unregistered version of Sheetcam. We found the key was not present.
Also you were using the wrong MP1000 post. It should have been MP1000-THC not MP1000-THCRefZ.
Owned by a license issue....damn! I never read anywhere about the Sheetcam license.
I switched the to the MP1000-THC RefZ last night at about 8:30 as a last ditch effort, and never changed it back...my bad! I was using MP1000-THC throughout the whole process
:D
