I'm in the middle of a axle swap on my CJ and I'm would like to get some input on my possible design.
I'm in the process of putting a Scout D44, SOA using YJ springs in my 74 CJ. Without changing knuckles and using as much stock parts as possible, I came up with the deisign of putting the draglink end joint into the tie rod. I would fab up a mount and weld it in or find a simalar tie rod with the hole already in. I know newer YJ & TJ use this system so I'm thinking it would work for me. The way I'm set up now would be extremly difficult to put the drag link on the knuckle. But I will go that way if there is no other choice. So my question is, should it work? I drive this about 50/50 on the road/trail.
Edit - It looks like I might be able to use a Waggy tie rod?
http://i423.photobucket.com/albums/p...teering001.jpg
