CJ8 Conversion Build going slow but going. Check back often.
really like what I'm seeing ! great job it will be a unique build :t:
Do I really need this since I am going w/a V8 & no fuel line return. It's 25 yrs old. I know the theory behind it but not really sure exactly.
Jim
http://www.street2mud.com/albums/M17...1825.sized.jpg
what is it? :-|
I believe that was part of the evap system. It would have been under the driver rear fender, and connected to a charcoal canister under the hood and gas tank. part of it is a check valve that would shut off fuel in case of a roll over. Just plug the fitting on top of the tank and pitch the rest.
The one on my CJ rusted and started leaking in less than 3 years, I took it off over 25 years ago.
It may be of some value to someone doing a stock restoration. Those parts are made from unobtainium. :?: :?: :?:
Yep, for sale to the highest bidder. The 21gal tank goes in this week :)
P.s. Mudrat, I think this is what U were looking for a couple years ago when I sent U that other part. :roll: :shock:
Well, the tank is in and plumbed, tranny lines run, re-built 3 core rad, rear brake lines in and ready to set the tub on Saturday :)
Trans cooler to add to the build-Hayden 1404
http://www.street2mud.com/albums/M17...1899.sized.jpg
http://www.street2mud.com/albums/M17...1900.sized.jpg
http://www.street2mud.com/albums/M17...1907.sized.jpg
http://www.street2mud.com/albums/M17...1909.sized.jpg
Mounted the lines on the motor mount for easy removal & they are far enough from the exhaust manifold.
http://www.street2mud.com/albums/M17...1908.sized.jpg
Rear brake hose installed
http://www.street2mud.com/albums/M17...1910.sized.jpg
T-case vent line installed
http://www.street2mud.com/albums/M17...1911.sized.jpg
Tank plumbed in. Ran vent line through the frame to the front/charcoal canister. Covered the S-Steel lines to prevent chaffing.
http://www.street2mud.com/albums/M17...1906.sized.jpg
Visit my gallery from time to time and check the progress.
[Street2Mud.com's Gallery
Well thanks to some of the CCJ club, the tub was installed today along with the 1" daystar BL. Sorry I couldn't get more involved pics but someone had to do something :) Next week, prep/paint.
Scott had to weld the two rear nuts inside the frame, when tightening, they spun.
http://www.street2mud.com/albums/M17...1914.sized.jpg
http://www.street2mud.com/albums/M17...1915.sized.jpg
http://www.street2mud.com/albums/M17...1920.sized.jpg
http://www.street2mud.com/albums/M17...1917.sized.jpg
Looks like I need to do some touch up painting, in the end of course.
http://www.street2mud.com/albums/M17...1919.sized.jpg
http://www.street2mud.com/albums/M17...1918.sized.jpg
http://www.street2mud.com/albums/M17...1921.sized.jpg
Notice the Twin Stick and the notch cut out, just enough and the original cover will still fit like original.
http://www.street2mud.com/albums/M17...1916.sized.jpg
Well, removed some surface rust, use por's metal ready, primed the bare spots to prevent more rust, sanded and wet sanded the tub. Next I will go over some shiners & the prime the entire tub with Red Oxide Primer.
Welded tailgate & primed it
http://www.street2mud.com/albums/M17...1922.sized.jpg
Sanded & ground the tub's rust spots
http://www.street2mud.com/albums/M17...1923.sized.jpg
Getting ready to "Metal Ready" the tub's rusted areas
http://www.street2mud.com/albums/M17...1924.sized.jpg
Wet down driveway
http://www.street2mud.com/albums/M17...1925.sized.jpg
Primed bare spots after wet sanding
http://www.street2mud.com/albums/M17...1926.sized.jpg
http://www.street2mud.com/albums/M17...1927.sized.jpg
http://www.street2mud.com/albums/M17...1928.sized.jpg
Sanded outside of tub
http://www.street2mud.com/albums/M17...1929.sized.jpg
Wet sanding outside of tub
http://www.street2mud.com/albums/M17...1930.sized.jpg
http://www.street2mud.com/albums/M17...1931.sized.jpg
http://www.street2mud.com/albums/M17...1932.sized.jpg
http://www.street2mud.com/albums/M17...1933.sized.jpg
http://www.street2mud.com/albums/M17...1934.sized.jpg
http://www.street2mud.com/albums/M17...1935.sized.jpg
CJ's RULE :)
http://www.street2mud.com/albums/M17...1936.sized.jpg
Bought some U-POL spray in bed liner for the conversion. Picked it up this morning and the guy sells POR-15 cheap. 25 bucks a pint and 35 (I think) for a quart.
http://www.street2mud.com/albums/M17...1973.sized.jpg
Some thing like that, but did the plug and chuck routine on my broke pieces too. And NOBODY re-pops those. It might have been a good idea at the time, but technology marches on and so did I :wink:Quote:
Originally Posted by rollbar
OK, the prep is done for the U-POL Raptor spray in bedliner. I have to wash it tomorrow morning and then tape it off/spray it.
Below are some pics of the POR-15 applied.
Bulkhead
http://www.street2mud.com/albums/M17...1983.sized.jpg
Backside of windshield hinges
http://www.street2mud.com/albums/M17...1984.sized.jpg
Windshield mounting locations
http://www.street2mud.com/albums/M17...1985.sized.jpg
http://www.street2mud.com/albums/M17...1987.sized.jpg
Front cowl. This will stay since it is behind the dash etc.
http://www.street2mud.com/albums/M17...1986.sized.jpg
Drivers side door jamb just above the joint
http://www.street2mud.com/albums/M17...1988.thumb.jpg
Bulkhead joint and side walls done
http://www.street2mud.com/albums/M17...1989.sized.jpg
Bulkhead installed
http://www.street2mud.com/albums/M17...1990.sized.jpg
http://www.street2mud.com/albums/M17...1991.sized.jpg
Now here is where I sanded the tub w/180 grit and hand sanded/buffed the tub w/a red Scotch pad per the U-POL instructions. I added the 180 grit, wanted the stuff to stick as good as it can.
http://www.street2mud.com/albums/M17...1992.sized.jpg
http://www.street2mud.com/albums/M17...1993.sized.jpg
http://www.street2mud.com/albums/M17...1995.sized.jpg
http://www.street2mud.com/albums/M17...1994.sized.jpg
Tomorrow I wash the tub, air dry it, tape it off and spray :)
Taping tub off for Raptor bed-liner spray
http://www.street2mud.com/albums/M17...1996.sized.jpg
http://www.street2mud.com/albums/M17...1997.sized.jpg
http://www.street2mud.com/albums/M17...1998.sized.jpg
Taping off the bolt holes etc.
http://www.street2mud.com/albums/M17...1999.sized.jpg
http://www.street2mud.com/albums/M17...2000.sized.jpg
Shooting the Raptor. IMO, a lot better then the roll on liner for the ease of application/looks
http://www.street2mud.com/albums/M17...2001.sized.jpg
First coat shot and out in the sun to bake
http://www.street2mud.com/albums/M17...2002.sized.jpg
Having fun
http://www.street2mud.com/albums/M17...2003.sized.jpg
Touch up out in the sun so I could see better
http://www.street2mud.com/albums/M17...2004.sized.jpg
http://www.street2mud.com/albums/M17...2005.sized.jpg
Finished, removing tape
http://www.street2mud.com/albums/M17...2006.sized.jpg
http://www.street2mud.com/albums/M17...2007.sized.jpg
http://www.street2mud.com/albums/M17...2008.sized.jpg
Jr removing some tape
http://www.street2mud.com/albums/M17...2009.sized.jpg
Jr removing the tape off the foot of the roll bar
http://www.street2mud.com/albums/M17...2010.sized.jpg
Tub complete
http://www.street2mud.com/albums/M17...2011.sized.jpg
http://www.street2mud.com/albums/M17...2012.sized.jpg
http://www.street2mud.com/albums/M17...2013.sized.jpg
http://www.street2mud.com/albums/M17...2014.sized.jpg
http://www.street2mud.com/albums/M17...2015.sized.jpg
Tub complete, sorry about the camera angle
http://www.street2mud.com/albums/M17...2016.sized.jpg
OD color contrast on how it will look when completed
http://www.street2mud.com/albums/M17...2017.sized.jpg
http://www.street2mud.com/albums/M17...2018.sized.jpg
Ok I'm tired and I am very please w/this product. Prep was 180 grit and then followed up by a red Scotch pad. I wanted it really scuffed due to some of the POR-15 used and old paint on top of paint. Way to easy w/the spray on. I had the compressor @ 120psi and regulated the spray @ the gun. I did some test shots w/just air w/the compressor set @ 50psi to get the feel, then raised the compressor and adjusted @ the gun. Worked out well and when I changed bottles I just unhooked the air line to keep the consistency for the next bottle. After the first coat & stuck the gun in some lacquer thinner and shot until the gun was clean. Waited an hour while it bakes in the sun & shot the last coat w/the main object concentrating on the bed since it will take the most abuse. So, how does it look? I'm sure it will pop when the OD gets on there. :)
Fenders & hood sanded
http://www.street2mud.com/albums/M17...2019.sized.jpg
POR-15 on lightly rusted areas
http://www.street2mud.com/albums/M17...2020.sized.jpg
http://www.street2mud.com/albums/M17...2021.sized.jpg
POR-15 on battery tray, hood support, vacuum can, jack plate & fender supports
http://www.street2mud.com/albums/M17...2022.sized.jpg
Since I am doing OD & black I think the black accents under the hood would look good.
Looks great Jim, and the "spray is the way"!!!! I did the roll on in the inside of the YJ (sprayed the undercoat) and it took 3 coats inside and doesn't look near that good!!!
Thanks Pat, and thanks for helping me get back on-line.
Hopefully I can shoot the outside w/OD tomorrow if not on Monday, we will see.
All that is left is:
Fuel pump
Exhaust routing/mufflers (using stock manifolds)
Cut rear drive shaft to fit
Lokar kick down (unless MC has one for a TF-999 to AMC 360)
Front brake hoses
Fix the windshield and get glass (75bucks)
Add the front bracket to the power steering pump
Get a return p-steering line
Install the interior
Get a mini spool for the rear (in time)
Make some rock sliders for the sides (this will cover the hole that I soaked the POR-15 into)
Transfer title/get tag
That might be it. Trying to finish no later than the first weekend in May but we will see. Moving 1June09
I'm glad I made this list, I might have to refer back to it 111!!!
P.S. I ordered the oil block off plate from MC a few days ago, hope it will help the 360.
Washed everything down for final paint
http://www.street2mud.com/albums/M17...2023.sized.jpg
http://www.street2mud.com/albums/M17...2024.sized.jpg
Taped off ready for final paint
http://www.street2mud.com/albums/M17...2025.sized.jpg
http://www.street2mud.com/albums/M17...2026.sized.jpg
Jr. putting on the final tape touches
http://www.street2mud.com/albums/M17...2027.sized.jpg
http://www.street2mud.com/albums/M17...2028.sized.jpg
http://www.street2mud.com/albums/M17...2029.sized.jpg
Testing spray gun pattern
http://www.street2mud.com/albums/M17...2030.sized.jpg
Painting hood
http://www.street2mud.com/albums/M17...2031.sized.jpg
Grill painted
http://www.street2mud.com/albums/M17...2032.sized.jpg
Roll bar painted
http://www.street2mud.com/albums/M17...2033.sized.jpg
Hood & bumper painted
http://www.street2mud.com/albums/M17...2034.sized.jpg
Fender painted, need final coat on the inner panel
http://www.street2mud.com/albums/M17...2035.sized.jpg
Painting tub
http://www.street2mud.com/albums/M17...2036.sized.jpg
http://www.street2mud.com/albums/M17...2037.sized.jpg
http://www.street2mud.com/albums/M17...2038.sized.jpg
http://www.street2mud.com/albums/M17...2039.sized.jpg
http://www.street2mud.com/albums/M17...2040.sized.jpg
Waiting second coat-this stuff drys fast in this heat so I waited about 30min
http://www.street2mud.com/albums/M17...2041.sized.jpg
http://www.street2mud.com/albums/M17...2042.sized.jpg
Applying second heavy coat
http://www.street2mud.com/albums/M17...2043.sized.jpg
Tailgate latches OD
http://www.street2mud.com/albums/M17...2044.sized.jpg
Final paint now drying
http://www.street2mud.com/albums/M17...2045.sized.jpg
Installing rock guards later so they will hide the damaged spots & I fill /soaked them w/POR-15
http://www.street2mud.com/albums/M17...2046.sized.jpg
http://www.street2mud.com/albums/M17...2047.sized.jpg
http://www.street2mud.com/albums/M17...2048.sized.jpg
http://www.street2mud.com/albums/M17...2049.sized.jpg
http://www.street2mud.com/albums/M17...2050.sized.jpg
Roll bar foot sprayed w/U-POL to blend in w/the bed-liner
http://www.street2mud.com/albums/M17...2051.sized.jpg
http://www.street2mud.com/albums/M17...2056.sized.jpg
http://www.street2mud.com/albums/M17...2052.sized.jpg
http://www.street2mud.com/albums/M17...2054.sized.jpg
http://www.street2mud.com/albums/M17...2055.sized.jpg
Underside of hood, note the black accents w/POR-15
http://www.street2mud.com/albums/M17...2057.sized.jpg
Look at that sweet CJ grill, just as happy as can be
http://www.street2mud.com/albums/M17...2053.sized.jpg
Other than the cancer under the "Jeep" logo and passenger 'B' piller - it looks fantastic!!
Ya I know, it would have been more of a headache to cut it out and re-weld it (I tried) since I have a el-chepo welder and it just melts the metal even when I do it in spurts. I POR-15 the heck out of it and poured it in there after the required prep so I don't think it will go anywhere. Plus, I rock guard will be covering this spots and covered in OD on the front & POR-15 on the back side.
Thanks for the complements,
Next the doors, dash and factory rims in OD w/the wheel having a Black accent on the outer edge. Stay tuned.
(NOS) WWII snorkel parts painted
http://www.street2mud.com/albums/M17...2072.sized.jpg
(NOS) WWII snorkel mast re-painted
http://www.street2mud.com/albums/M17...2073.sized.jpg
(NOS) WWII snorkel mast mounted with stainless steel bolts
http://www.street2mud.com/albums/M17...2074.sized.jpg
http://www.street2mud.com/albums/M17...2075.sized.jpg
Roll bar bolted in with grade 8 bolts which will be touched up with black paint
http://www.street2mud.com/albums/M17...2076.sized.jpg
(NOS) Reflector location
http://www.street2mud.com/albums/M17...2078.sized.jpg
(NOS) Snorkel nose being straightened
http://www.street2mud.com/albums/M17...2080.sized.jpg
How you going to get it out of the garage? I have to drop to 5psi to clear the door, but then I have 35's on mine :sa:
Garage door is 9' :)
Snorkel installed
http://www.street2mud.com/albums/M17...2081.sized.jpg
http://www.street2mud.com/albums/M17...2082.sized.jpg
http://www.street2mud.com/albums/M17...2083.sized.jpg
http://www.street2mud.com/albums/M17...2084.sized.jpg
Final hose placement
http://www.street2mud.com/albums/M17...2085.sized.jpg
Measuring for cut out
http://www.street2mud.com/albums/M17...2086.sized.jpg
Cutting hole, note the safety gear
http://www.street2mud.com/albums/M17...2089.sized.jpg
http://www.street2mud.com/albums/M17...2087.sized.jpg
http://www.street2mud.com/albums/M17...2088.sized.jpg
Trimming fender lip, gotta love the guard on the cutter
http://www.street2mud.com/albums/M17...2090.sized.jpg
Trimming fender edge with a file
http://www.street2mud.com/albums/M17...2091.sized.jpg
After many times of raising the hood for fitment we have finished. I know the front is supposed to have a "S" shape but I wanted it close.
http://www.street2mud.com/albums/M17...2092.sized.jpg
http://www.street2mud.com/albums/M17...2093.sized.jpg
Front snorkel & clip
http://www.street2mud.com/albums/M17...2094.sized.jpg
http://www.street2mud.com/albums/M17...2095.sized.jpg
Jr getting the wiring sorted and cleaning up the parking brake connector
http://www.street2mud.com/albums/M17...2096.sized.jpg
http://www.street2mud.com/albums/M17...2097.sized.jpg
http://www.street2mud.com/albums/M17...2099.sized.jpg
Under hood wiring
http://www.street2mud.com/albums/M17...2098.sized.jpg
Jr getting the dash stripped for paint
http://www.street2mud.com/albums/M17...2100.sized.jpg
Dizzy pigtail from PO
http://www.street2mud.com/albums/M17...2101.sized.jpg
http://www.street2mud.com/albums/M17...2103.sized.jpg
Dizzy pigtail from PO, notice the green wire on this tail
http://www.street2mud.com/albums/M17...2104.sized.jpg
http://www.street2mud.com/albums/M17...2105.sized.jpg
Dizzy pigtail from factory harness
http://www.street2mud.com/albums/M17...2102.sized.jpg
Wiring under hood
http://www.street2mud.com/albums/M17...2106.sized.jpg
Jr. sanding dash panel
http://www.street2mud.com/albums/M17...2107.sized.jpg
Dash panel painted and drying
http://www.street2mud.com/albums/M17...2108.sized.jpg
http://www.street2mud.com/albums/M17...2109.sized.jpg
Dash panel dried
http://www.street2mud.com/albums/M17...2117.sized.jpg
Spare mount, need to add spacer and angle up-wards for the 33" tire to fit
http://www.street2mud.com/albums/M17...2115.sized.jpg
http://www.street2mud.com/albums/M17...2116.sized.jpg
Reflector mounted in the area of the original Jeep M-170
http://www.street2mud.com/albums/M17...2114.sized.jpg
Jr. laying out the figures for the name placement
http://www.street2mud.com/albums/M17...2110.sized.jpg
http://www.street2mud.com/albums/M17...2111.sized.jpg
Jr. laying out the name
http://www.street2mud.com/albums/M17...2112.sized.jpg
Last name layed out
http://www.street2mud.com/albums/M17...2118.sized.jpg
Whole name layed out
http://www.street2mud.com/albums/M17...2119.sized.jpg
Stripping away the tape to reveal the name
http://www.street2mud.com/albums/M17...2120.sized.jpg
Name complete
http://www.street2mud.com/albums/M17...2122.sized.jpg
After scuffing the letter cut outs with a scotch pad I painted the name on the Jeep
http://www.street2mud.com/albums/M17...2124.sized.jpg
Name revealed. This was my old name on the Willy's, it came from the Military with it on the Jeep so I thought I would resurrect it
http://www.street2mud.com/albums/M17...2125.sized.jpg
http://www.street2mud.com/albums/M17...2126.sized.jpg
http://www.street2mud.com/albums/M17...2127.sized.jpg
To replace the heater core. Remove the back cover, use a 1/4" driver and it takes a 1/4" socket.
http://www.street2mud.com/albums/M17...2154.sized.jpg
Remove heater core
http://www.street2mud.com/albums/M17...2155.sized.jpg
Replace heater core and reinstall the back cover
http://www.street2mud.com/albums/M17...2156.sized.jpg
After installing the back panel paint the panel with POR-15 to prevent rust from reoccurring
http://www.street2mud.com/albums/M17...2157.sized.jpg
Tape of gauges for paint
http://www.street2mud.com/albums/M17...2158.sized.jpg
http://www.street2mud.com/albums/M17...2160.sized.jpg
Paint the back side of the dash with POR-15 to prevent rust in the joints and where the metal to metal meet
http://www.street2mud.com/albums/M17...2161.sized.jpg
Gauges installed
http://www.street2mud.com/albums/M17...2162.sized.jpg
http://www.street2mud.com/albums/M17...2164.sized.jpg
Gauges wired up, hope they are right
http://www.street2mud.com/albums/M17...2165.sized.jpg
http://www.street2mud.com/albums/M17...2166.sized.jpg
Panel wired up/items installed
http://www.street2mud.com/albums/M17...2167.sized.jpg
Installing dash
http://www.street2mud.com/albums/M17...2168.sized.jpg
http://www.street2mud.com/albums/M17...2169.sized.jpg
Dash install complete
http://www.street2mud.com/albums/M17...2170.sized.jpg
Forgot to get the seatbelt bolt out for new seat belts (didn't hurt the U-POL bed liner). Had to weld a bolt on the torque head.
http://www.street2mud.com/albums/M17...2171.sized.jpg
Installing seat bet latches
http://www.street2mud.com/albums/M17...2177.sized.jpg
Installing drivers seat
http://www.street2mud.com/albums/M17...2178.sized.jpg
http://www.street2mud.com/albums/M17...2179.sized.jpg
http://www.street2mud.com/albums/M17...2180.sized.jpg
Installing passenger seat
http://www.street2mud.com/albums/M17...2181.sized.jpg
Pinched finger, bracket is bent, need to straighten it out more than I did
http://www.street2mud.com/albums/M17...2182.sized.jpg
Seats in. Need to get a longer bolt for the set belt to roll bar
http://www.street2mud.com/albums/M17...2183.sized.jpg
Pretty awesome Jim your booking through this project!! Is that the kid helping you? I need to make it down for a scramble so I can hold Pat back from stealing jeeps after a few brews :?: errrr :mrgreen:
Yes, long nights & that is my son, I went to Alabama this past weekend and picked up my daughter who graduated with honors from Faulkner University w/a AS in Biology, she is the one who jumped in on the last set of pics to help out. I might need some help w/a part of the engines wiring and will post later in the engine section. Have to run down to Tampa to see a heart/kidney patient.
I have factory rims I'm going to paint up later, I am moving @ the end of the month and wil finish the toucjes after, want to drive it to the next location :)
Thanks again,
Jim
P.S. I have not received the parts/tracking # yet.
Jim, were you at the Scramble this year?? Did I miss you somewhere??
And MC - I was (fairly) sober when we made off with the midget's (Will's) Jeep!!
Nope, maybe next yr.
Installed new seat belts with grade five bolts, hardened washers and loc-washers
http://www.street2mud.com/albums/M17...2184.sized.jpg
Temporarly bolted the tops to the roll bar
http://www.street2mud.com/albums/M17...2185.sized.jpg
http://www.street2mud.com/albums/M17...2186.sized.jpg
Need longer feed through bolt for hard top installation
http://www.street2mud.com/albums/M17...2187.sized.jpg
http://www.street2mud.com/albums/M17...2188.sized.jpg
They make'm :-)Quote:
Installing 195* T-stat
http://www.street2mud.com/albums/M17...2189.sized.jpg
PO used plenty of goop & blocked off the goose neck outlet
http://www.street2mud.com/albums/M17...2190.sized.jpg
http://www.street2mud.com/albums/M17...2191.sized.jpg
My daughter installing the master cylinder
http://www.street2mud.com/albums/M17...2192.sized.jpg
Removed PO block off plate and installing the 6505 fuel pump
http://www.street2mud.com/albums/M17...2193.sized.jpg
http://www.street2mud.com/albums/M17...2194.sized.jpg
http://www.street2mud.com/albums/M17...2195.sized.jpg
http://www.street2mud.com/albums/M17...2196.sized.jpg
http://www.street2mud.com/albums/M17...2197.sized.jpg
Water pump hose installed
http://www.street2mud.com/albums/M17...2198.sized.jpg
3/4" heater hose installed
http://www.street2mud.com/albums/M17...2199.sized.jpg
Starter solenoid installed
http://www.street2mud.com/albums/M17...2201.sized.jpg
Great progress, looks like Advanced came through with a fuel pump. The Thermostat housing looks like it might be a replacement cast iron piece sold by parts stores that is actually made for an Oldsmobile and will fit an AMC but doesn't line up very well with the pad, bolt holes, or ports in the intake. They work, but an actual cast aluminum AMC thermostat housing would fit, line up, and seal better, for what it's worth, not a big deal, just mentioning it.
Wow, I didn't know that. When I took it off the PO had broken the left ear off the INTAKE :shock: :(: :(: :(: where the bolt goes into the intake. I sealed it up and put a 195* stat in and it's tight. I hope it doesn't leak, it shouldn't cause it's on the passenger side of the ear. Some people. I wonder what else is rigged in this motor :shock: :roll: #-o
Spliced spare module for the nutter by-pass, heat shrinked connectors and greased connector
http://www.street2mud.com/albums/M17...2202.sized.jpg
Module ready to install
http://www.street2mud.com/albums/M17...2203.sized.jpg
Module installed
http://www.street2mud.com/albums/M17...2207.sized.jpg
Radiator over flow jug
http://www.street2mud.com/albums/M17...2205.sized.jpg
Need bracket for over flow jug
http://www.street2mud.com/albums/M17...2206.sized.jpg
Radiator, hoses and fan installed
http://www.street2mud.com/albums/M17...2208.sized.jpg
Heater hoses & fuel line to carb installed
http://www.street2mud.com/albums/M17...2210.sized.jpg
Tranny cooler installed-courtesy of TransTech of Ft. Lauderdale, Florida
http://www.street2mud.com/albums/M17...2209.sized.jpg
Can I do this for off-road and cut vent lines in the top of the hose?
http://www.street2mud.com/albums/M17...2212.sized.jpg
Is this port for the vacuum advance for the distributor?
http://www.street2mud.com/albums/M17...2214.sized.jpg
looking real good :t: :t:
Look what Summit sent me. Called Lokar & saved big time going w/Summit.
http://www.street2mud.com/albums/M17...2215.sized.jpg
Watch your eye's guys . . . a blinged out M170 :shock: :t: :mrgreen:
What U talk'in bout Willis :mrgreen:Quote:
Originally Posted by Mudrat
Installed Lokar's kick down bracket
http://www.street2mud.com/albums/M17...2217.sized.jpg
Installed radiator cap (all they had was a 16lb)
http://www.street2mud.com/albums/M17...2218.sized.jpg
Installed foot dimmer switch
http://www.street2mud.com/albums/M17...2219.sized.jpg
Installed fuel filter
http://www.street2mud.com/albums/M17...2221.sized.jpg
Accel super coil (need bracket), mine is rusted but workable
http://www.street2mud.com/albums/M17...2222.sized.jpg
Installed OC handle
http://www.street2mud.com/albums/M17...2224.sized.jpg
Received the air/vent cables and the front extended brake lines
http://www.street2mud.com/albums/M17...2225.sized.jpg
Vent cables installed but the TEMP knob pulled off the hard line. Nothing like factory, maybe JB weld will hold it
http://www.street2mud.com/albums/M17...2226.sized.jpg
