OK,
So I go to roll the CJ outta the shop, and it won't move :-|
Found the right front 'locked up'. Jacked it up, tire won't roll, removed the tire and put a 4' prybar on it, won't move. Pulled the hub assy apart and found the inner bearing was "josayed". Guess that explains the pull to the right :mrgreen: Or in military parlance it's AFU!! As in the inner bearing came apart and I scooped the rollers out with the grease :shock:
So, now I'm looking for parts for a Dana-44 that I thought was from a Waggy, but the numbers don't match the book nor do they match Nygords list of flat top knuckles :shock: The Jeep part CD pictures are really blurry (and yes, I'm wearing my glasses 8) ).
So, what I have is:
Pumpkin is a D44, no BOM data on the tubes or webbing???? What's up with that?!?!?!
Knuckles, flat top, High steer (look like a Chevy or FSJ dana 44) And by the way MC, the new Heims look MARVELOUS on that 1.5 DOM :!: I especially like the adjuster :t:
knuckle casting number of 636519 (or C36519?)
Nothing on the DISC brake, or rotor assy (really rusty and need blasting) has a 6 bolt mount to the knuckle.
Shaft is a 19 outter, 29 inner(?) Shouldn't that be 30 or 31???
inner seal 47(2?)71 (rusty and cann't get a clear look)
Inner race LM104910
Inner BRG LM104949 (this is the one I scooped the rollers out of the grease)
Outter BRG LM501(3 OR 9)49-N (BRG is blue from heat and hard to read.
Outter race LM5011310
Any help is appreciated!! :mrgreen:
