Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2962 401 exhuast options
I should be ready to have the exhaust fabbed up end of this week. I need some options of routing and exist. It will have inframe headers. I have read of doing the y pipe, but do not thing this is an option with these headers. They are fairly long and point to the rear at the collector. Pics would be wonderful. What have you all done. Almost forgot. It is going in a CJ7 with TF727 tranny.
07-21-2006, 08:10 AM
401ton
I think you should re-think long tube in frame headers for a CJ.
I run exhaust manifolds for wheelin. Good low end torque, they fit good, no leaks, dual exhaust is easily routable and they don't rust out.
If I was to run headers for my wheeler, I would buy the Edelbrock shorty block hugger headers so routing was more accessable.
07-21-2006, 11:40 AM
1980_Cj7
I have not completely decided that I am using these headers. I just have always wanted something with headers and I got these at a steal. If I can make the exhaust route ok then they will stay, if not, they are history because this is a serious crawler that drags on stuff.
07-21-2006, 02:21 PM
If you 'wheel, you should do something like I have. Stock manifolds, 2.25" pipe out of the manifolds. The passenger side loops forward and crosses under the front of the oil pan, it turns back, and joins with the drivers side. Where they meet, it goes to 3". 3" high flow cat (smog rules), 3" magnaflow welded muffler. The only place the exhaust is lower that the frame rail is where is dumps behind the driver rear wheel.
I've never caught it on anything, and it doesn't leak. I can't tell a difference in torque or HP from when I was running headers and duals. Bonus is I can talk to my passengers without yelling (guess I'm getting old :-| ).
07-22-2006, 05:50 PM
1980_Cj7
How about some good pics of that set up, I will need to take them to the exhaust shop with me.
Ok heres the latest. Upon having the motor in the Cj and test fitting the headers, its not going to work out for me. With the t case clocked the outlet is sitting on the front drive shaft. I have picked up some manifolds and it will be going to the exhaust shop next week. Still havnt decide if I will be running single or duals yet though.
09-04-2006, 03:50 PM
wizzard
headers
you run in frame headers you are going to have a problem if you have to work on the starter. can't get to the starter for the header. i run stock manifolds have the muffler shop run duels all the way to the back of the transfercase then put your mufflers on.
09-05-2006, 10:22 PM
CJim7
I ran duals straight back with the stock manifolds (like Wizzard) and it works great. Everything is tucked up above the framerails nicely.
Bob, im curious after seeing the pic of the crossover. With it virtually wrapped around your oilpan, do you experience any hotter then normal running temperatures? looks like an oil-boiler you got there. Or does the pic just make it look closer then it is. :-|
09-12-2006, 09:43 AM
Actually, the pics make it look closer than it is. I haven't experienced any loss of oil pressure due to heat that I'm aware of. My engine runs about 20-25 PSI at hot idle, and 55-60 PSI runninf down the road (hot). It does get good airflow. I've never really worried about it.
Just the extra ground clearance from no Y-pipe inder the driveshaft and trans, and not having to worry about crushing anything is worth it.
09-23-2006, 07:25 AM
eight
I run stock cj manifolds (from an IH dump truck). The exhaust goes straight back along the frame rails, the passenger side crosses over to the driver side just behind the transfer case. I run a glasspack just behind the rear axle because that's the only place I could fit any sort of muffler with my link suspension. Points out the back with the turn down welded directly to the glasspack. It's not too loud like this, but I would like quieter if I could. Before the link suspension I had a 94-97 powerstroke muffler ( 3.5" in/out, straight through, stainless) in the normal spot and it was very quiet, I prefer that for trail rides.
