amc 20 model set-up bearings
looking for some one to make up a set of bearings, that when you rebuild the rear end you can put the bearing on free hand, the inside of the bearing is 3" or 4" thousand bigger than the case hub and the big bearing on the pinion is also 3" or 4" thousand bigger, the reason for this is when you set-up the pinion with the right amount of shims for the depth and when you get you back- lash set with the right amount of shims, this will take about 3 or 4 times to do this and after you got everything done, you can take the set-up bearings off by hand and then you press on the new bearings and then your done. this is for us guys that do not have the depth adjustment tool. i hope you guys understand what i'am taking above, this is the old way of doing a set-up, thanks amx4410
