its very well i may be wrong .. going from memory from past building days. but as i remember it, if you have an 18 floor joist, you cant cant. it more than 6. but as i write this ,... it does seem wrong, doesnt it?
Two things will do this. One is the pressure of the pump handle set by a little tension spring. The other is the vent on the tank. Some fill hose angles can cause pressure to build up at the nozzle tip but not in a TJ...most likely a plugged vent. That is if the TJ doesnt use the cap as a vent.
Pretty common. I just hold the nozzle back a little and dont try to use the cruise control
