I would like to make a anvil for a press brake. is it possible to set up my plasma table to cut a bevel on a piece of 1 inch thick stock about 20 inches long?
Thanks, Gary
Thanks, Gary
We will have info next week on it. BUT be warned that cutting at an angle ESPECIALLY at one inch thick means you are cutting much thicker than one inch and your plasma cutter may not make the cut. If you could cut so your cutting half that one inch then flipping it for the 90 degree angle on a die then you could use a powermax 86.
I would be cutting half as i would be making a point on that one end.
