TF-999 Leaking from Shift Lever/Kick Down
Well, I was going to change out the gasket/filter today (TF-999) since I did see a leak around the gasket. Upon further investigation I looked w/a flash light and I am seeing where the shift lever/kick down lever is mounted, the gasket is leaking. SO this is where my leak is coming from, nice bright red fluid.
Question: do I have to drain the pan to fix this, or can I just pull the levers. I'm thinking it is like a through bolt and needing to pull the pan to replace the gasket/ring for these levers.
I did come across the manual below but it really doesn't go into detail about this (unless I didn't see it). Looking at the picture, it looks like if things are unbolted from the top side it should slide out but I'm not sure if the GASKET is just on the top side or is there one on the inside as well.
Any help would be appreciated,
Jim
http://www.street2mud.com/albums/M17...t_Switch_1.jpg
