Without it breaking all the time- 33 35? Im guessing that 35s would be pushing it, but i figured that i would ask.
Jesse
Jesse
I have seen a 38 , it all depends on what you do, even a 31 15:50 terra tire can blow apart a 30, what size do you wan to run??
I was hoping 33 -35s. maybe. thats if i can afford em. IM not reall planning on putting mutch power to it. I seriously doubt that I'll run a V8 so were talking At most 258 power.
not a daily vehicle and probably fairly light, just a caged buggy.
But then again, 31s wouldnt be too bad, cause I wont be worried about body damage- Mash it and hang on!
Jesse
I can get you a set of 31 15:50 15 terra tractor tread tires for about $400 if your interested!!
What on earth do they look like? are they agricurltural Tractor style tire??
If i had money, I would be interested, But at the moment, I havent a Rig to put anything on.
Jesse[/img]
http://store.yahoo.com/jimscustomvw/terratires.html or check tou this one http://www.goodyear.ca/tires/tirecatalog/STGSize.html they are all cool tires 4x4.s
:P YESSS Ever seen those Terra tires used ona Jeep? I wonder how well the tread holds up under vehicles heavier than VWs. Those Goodyears are a bit much for me. Ill have a set of boggers first, only because i can run them abover 30 mph :oops:
Jesse
actually they suck on the road the tread is kinda soft, but off road i would take em over boggers anyday size for size!! :D
SO How many miles would you expect of commuting between the house and the trail before you had no tread? 5000 miles?
They are a wild looking tire. and around here, Nobody would know what they are.
Jesse
i would say about that, you could also change em out when you get there!!
