Good Used/Quality parts for AMC V8
Below is the list of parts and prices....
AMC 360 bored .030" (4.110") with brass freeze plugs installed internal oiling mod... $100
Holley 670 Street Avenger Carb... $100
Edelbrock Performer Intake... $100
Timing Cover with Mid-plate and gears... $100
502 Heads Milled and Machined with 7/16" studs installed, hardened guideplates, brass freeze plugs... $350
AMC Legend Valve Covers... $150
Harland Sharp 1.7:1 Roller Rockers P/N: S4004-77... $200
Comp Cams Magnum Chromoly One piece .080" Wall Pushrods... $50
Ross 10:1 Forged Race Pistons & Scat 343 Forged H-Beam Rods with ARP bolts (assembled)... $550
Crank turned 10/10... $50
Comp Cams 280H Magnum Cam, Lifters (lifters match lobes, no miss-matching), valve springs and 10* super locks... $75
Comp Cams Double Roller Timing Set... $50
1 5/8" to 3" Dynomax headers & 3" purple hornies (CJ)... $50
7.5 quart oil pan... $175
HEI Distributor... $50
Cardone Distributor with msd Cap adapt... $50
Pro Comp 6al Ignition Module, High Energy 50,000v coil & 8.5mm wires... $150
Two starters... $50
I'll add more stuff when I find the time to go through the garage.
If you want pics send me a text at Seven 5 Seven 9 one 8 one 9 one 7
Rich
