Its a journey fir sure Bob! Cant wait to see more progress!
7/27/12 Been a while. Got the Rogue back from media blast today.
Tore the front suspension out and built some rollers.
http://img.photobucket.com/albums/v4...e/MVC-646S.jpg
Removed the brace from the firewall before media blast. The 66 brace is on the right, the bigger 69 brace on the left will be spot welded in.
http://img.photobucket.com/albums/v4...e/MVC-649S.jpg
http://img.photobucket.com/albums/v4...e/MVC-650S.jpg
Back home without paint.
http://img.photobucket.com/albums/v4...e/MVC-651S.jpg
http://img.photobucket.com/albums/v4...e/MVC-653S.jpg
Not too many surprises, it has the standard rust in front of the rear wheels.
http://img.photobucket.com/albums/v4...e/MVC-654S.jpg
http://img.photobucket.com/albums/v4...e/MVC-657S.jpg
The one surprise was the drivers front fender that I thought was good. It had heavy undercoat on the back, and must have had filler on top. I think I can still save it.
http://img.photobucket.com/albums/v4...e/MVC-658S.jpg
http://img.photobucket.com/albums/v4...e/MVC-659S.jpg
Old repairs in the driver door.
http://img.photobucket.com/albums/v4...e/MVC-660S.jpg
Dent in the roof.
http://img.photobucket.com/albums/v4...e/MVC-662S.jpg
Trunk lid will need some attention. Old repairs here too.
http://img.photobucket.com/albums/v4...e/MVC-663S.jpg
http://img.photobucket.com/albums/v4...e/MVC-664S.jpg
Trunk floor had some hidden rust too. Probably cut that out and use an early Mustang tank.
http://img.photobucket.com/albums/v4...e/MVC-665S.jpg
Bonus.. The repro scoop showed up today. Excellent piece.
http://img.photobucket.com/albums/v4...e/MVC-668S.jpg
Now..... Down to the body work.
Its amazing what shows up after blasting. Where did you bring the body and how much if I may ask did they charge you to blast it?
I took it to a local place called Blast-Tech. They did everything forward of the firewall, front fenders inside and out, hood and trunk lid inside and out, and inside the trunk, along with the hood hinges and a few misc pieces. Used plastic media to remove the paint from the body, then something more abrasive just in the areas that had old filler. The whole deal cost me $1100. I think it's the only way to do a car right. The old paint was some sort of single stage stuff (maybe Imron) that was put on 12-15 years ago, I didn't want to go over it, and I didn't know what was under it. This way, I start fresh.
9/30/12. Been a while but I'm slowly working on it. Over the last couple of weekends, I've taken the factory AMC20 out (3.15/open) and tacked in the Control Freak 4 link brackets.
http://img.photobucket.com/albums/v4...j/MVC-713S.jpg
http://img.photobucket.com/albums/v4...j/MVC-712S.jpg
Undercoat cleaned off where the new brackets will be.
http://img.photobucket.com/albums/v4...j/MVC-714S.jpg
First test fit of the Control Freak bracket.
http://img.photobucket.com/albums/v4...j/MVC-715S.jpg
A couple of shots of the control arm and coilover bracket tacked in place.
http://img.photobucket.com/albums/v4...j/MVC-722S.jpg
http://img.photobucket.com/albums/v4...j/MVC-723S.jpg
The narrowed Ford 8.8 with the brackets welded on. Didn't have time to take shots during the test fit and tacking of the brackets.
http://img.photobucket.com/albums/v4...j/MVC-724S.jpg
http://img.photobucket.com/albums/v4...j/MVC-726S.jpg
The shortened left tube. This axle will be 56 5/8" WMS/WMS. The stock axle is 56"
http://img.photobucket.com/albums/v4...j/MVC-725S.jpg
any updates?
