401, 727, CJ parts....
Well I need to finish cleaning out my garage and here is what I have left:
*401 - Disassembled block, heads, crank, edelbrock performer cam, misc parts
*115 amp custom made alternator for AMC V8
*Edelbrock performer intake and 600cfm carb w/ off road kit, 14" dropped airfilter - 20 minutes use
*Slightly used radiator (about one years use with a 304)
*TF727 - condition unknown
*B&M Mega shifter - used in my CJ for the TF727
*Lokar kickdown cable AMC V8 to TF727
*CJ7 Hard doors - red with lightly tinted windows
*2 Flowmasters - 2.5 inlet centered in and out - surface rust and used
*CJ exhaust manifolds AMC V8
*Scout 44's setup for spring over, caster added (comes with "wagon" style wheels wheels)
*CJ7 Gas tank/sending unit - couple years old, stock style, comes with factory skid, used for about 2 years
*New CJ hood
*Used CJ hood
*33" BFG Mudterrain - old style - brand new on 15X10 wheel w 5on5.5 bolt pattern
Lots of other items that I know I'm forgetting - email me if you are looking for something...
Jack
lifted79CJ7@aol.com
Also have stock CJ seat frames with worn out low back seats as well as a BestTop Sunrider soft top for a CJ7 for sale.
I can't believe no one isn't lookong for something!
what are you asking for the block and what bore is it ?
Prices man.........prices
Hellooooo...Jack...Anybody out there...???????? :?:
how much for the intake or the intake and carb combo
My bad!! Here ya go.... I am willing to seperate for the right price - make an offer : lifted79cj7@aol.com
Just let me know what you are interested in!
1978 AMC 401 - $500.00
Disassembled and ready for machining and rebuild
Block has had the inside pressure washed out
Includes the following parts:
*Block
*Crank
*Rods
*Pistons (need to be replaced)
*Heads (no valves or springs)
*Edelbrock Performer (all only 20 minutes use):
***Performer Intake
***600 CFM Carb
***14" Airfilter
***Cam/Lifters
***Timing Chain
*New push rods
*All original engine bolts
*Water pump (used - should be replaced)
*Accessory Brackets and Bolts
I also have a:
*Bulltear oil filter relocation kit for $75 still new in the box.
*115 Amp high output alternator - $75 (Paid over $250 new)
*CJ Style exhaust manifolds - $35
*Flowmasters - $50 for both (2.5" inlet and outlet centered)
*Radiator - $50
Things I have already sold but you will need to replace:
Timing chain cover and gears
Valves
Valve springs
Distributor and wiring
Distributor gear and cam gear
Hood $75.00
Hood $10.00
Seat Frames - $50.00
Tire/Rim - $100
Dana 44's - Scout II - $450 - Same for what I paid for them, except I put a lot of work into them. :)
*Spring over
*5 degrees caster added
*Slightly used new front discs and calipers - used for ~3000 miles on my CJ on the stock dana 30, swapped them to the 44.
*3.08 gears - Bears and seals have seen better days
*Rear is lincoln locked
*Rear drum brakes - have new hard lines installed and brake cylinders still in bags
*I would reweld the rear perches - ran out of flux core and mig welded on gas - welder wasn't big enough to penetrate correctly - easy 30 minute fix.
Soft top - $125
Black Sunrider - couple brackets are bent but can be fixed easily.
Hard doors - $120
Red - older style (not paddle style)
Red paint, black interior trim, tinted windows
Steel Gastank/pickup tube/hoses ~3 years old/1977 skid - $80
CJ Brackets - $50
CJ brackets are the kind that allow the passenger to flip forward, but the drivers does not. The drivers does slide forwards and back on a track though. Remind me tomorrow and I'll take some pics for ya!
Lokar kickdown cable - $20
B&M Shifter - $50
Comes with Bulltear shifter handle that says 401 CJ7
TF727 - Condition unknown, selling for price paid - $50
Do you still have the original shifter handle for the B&M shifter, if so, I'll take it. Right away. I might like the Flowmasters as well.
what about just this
*Block
*Crank
*Rods
