Jay from Washinton, thanks for the e-mail,I was not thinking and did not save it . Please do it again with your phone number.You called me,but new touch phone,learing to use it and lost your number. AMX is almost done last pull was 477 HP at the tires. Walt QUICKAMX@SBCGLOBAL.NET 916-747-0051
Hi guys here it is final numbers I dont know how to show you the dyno chart but my boy will, REAR WHEEL HP 502.9 TORQ 548.7 ,I AM HAPPY ,STREET GAS JUST THRU THE INTERCOLLER . WALT
3 Attachment(s)
DYNO CHARTS
DYNO CHARTS FROM PAST TO PRESENT MANUAL AUTOMATIC TO 4SPEED TO SUPERCHARGED. DON FROM MOTOR MACHINE THINKS HE CAN GET MORE OUT OF IT. IM OK WITH WHERE IT IS.
Attachment 388Attachment 389Attachment 390
1 Attachment(s)
Hi guys this is it one torky rambler.Walt
Attachment 392
This is stan..... I'm a frend of walt's and have helped him thru the whole process with this amx for over 20 plus years.!! After getting his amx back from don's motor machine shop, he drove it home and told me i had to drive it.we always go down the freeway and head back to his house which is about a mile away. We use an on ramp which is shielded from the freeway by large trees and bushes. I got on the on ramp, slowly,shifted to second gear at about maybe 20 mph then nailed it. It pulled strong,then, all hell broke loose when the boost came in. The ass end came around to the left about 45 degrees.... Had i stayed in it another half second we would [ or ishould say i would] have rolled it over or done a 360 right there. All we could see was the trees and bushes out the the windshield, i corrected and then all we could see was the slope on the other side of the on ramp. We made it !! Both shook up !! All walt has wanted was a strong street car..... Well buddy he has it!!! That mother has so much frigging torque at low rpm..... And pulls so strong all the way. We crawled back to his place on the freeway,put the car in the garage and went to the bar! Shook the shit out of both of us. I realized i'm [ too frigging old ] to handle it!
Hi guys car is to much for me, but I would like to make it right for my son,or next owner. I know the rear end is the weak link, ford 9 inch with disc brakes sounds best to me. Anyone have advice I would welcome it ,thank you Walt.
Walt
Goops here. I run a 9 in with disc brakes in my rebel wagon. It is out of a Lincoln Versailles and should be the correct width for your car. Should be able to find one in your area.
After you install it you will probably need better brake boost and i went to a hydroboot system. I use Mosher spool and 33 spline Mosher axles in mine.
Goops
Superchargers are a riot. You have to be careful or they get away from you fast. Especially when your not on a track and are staged with slicks.
503 rear wheel hp and almost a 200hp gain is really a good number. And at over 360 ftlbs of torque I would say that supercharger in the AMX should be the cheapest power upgrade per benefit.
Hi I am Walt, if anyone would like information on this supercharger setup ,fell free to call me at 916-747-0051 7 to 9 am pacific time thanks.
