Try unplugging all the motors then fire it up. Also if your charge pump is on you wont get it to run. You re-wired a drive so maybe a loose wire to the drive, power or ground. I also have to remind you it has been 3+ years since you got the machine and 3+ years since you promised a write up.
I will try unplugging everything, and also check all the wiring on the Gecko!!
I have the writeup about the plasma side basically done, I just wanted to get some routing info in there as well. I have everything for the routing (bits, material, router, etc), but need to get the table running again. If I can't get anything going in the next few days, I'll have them post the writeup with the plasma info, and then update once I get the routing done.
