from 1951-present
30 spline after 72' pre72' 19 spline
factory ratios 2.76-5.89
Mostly semi float (RARE FULLFLOATING)
5-6-8 lug
Weak points stock carrier and spider gears
used in front and rear applications
from 1951-present
5-6-8 lug
here is a list of dana 44 WMS to WMS lengths from jeeps
'41 to 45 Jeep MB: 48.25"
'46 up CJ-2A, CJ-3A : 48.25"
'49-65 Jeep Utility Wagon: 57"
'49 Willys Jeepster 2WD 57"
'52 up CJ-3B: 48.44"
'52 M-38A 49.19" (Military width)
'54-71 CJ-5 48.44" (so called early-
'55-75 CJ-6 48.44" narrow axle)
'47-65 Pickup (the classic) frnt-56" rr-63.5"
'63-69 J-200, J-2000 65.5"
'63-69 J-300, J-3800 65.75"
'70- 72, Gladiator J-2000 frnt-63.5" rr-63.81"
'70- 72, Gladiator J-4000 frnt-63.8" rr-64.38"
'73 J-2500 frnt-63.5" rr-63.8"
'73 all other J trucks frnt-63.9" rr-64.4"
'74-75 J-10 frnt-62.9" rr-63.8"
'76-87 J-10 frnt-63.3" rr-63.8"
'74-75 J-20 frnt-62.9" rr-64.4"
with disc brakes: frnt-63.0" rr-64.4"
'76-84 J-20 frnt-64.9" rr-65.9"
'63-72 Wagoneer 57"
'73 Wagoneer frnt-57.3" rr-57.5"
'74-75 Wagoneer frnt-59" rr-57.5"
'74-75 Cherokee (full size) frnt-58.8' rr-57.5"
'76-91 Wagoneer, '80+ Cher frnt-59.4" rr-57.8"
'76-79 Cherokee (full size) frnt-59.2" rr-57.8"
'76-78 Cherokee S frnt-59.5" rr-58.5"
'76-80 Cherokee Chief 2 dr. frnt-65.4" rr-62.3"
'81-83 Cherokee Chief 2 dr. frnt-65.3" rr-62.3"
'67-71 Jeepster C-101 50"
'72-73 Commando C-104 frnt-51.5" rr-50"
'72-83 CJ-5, frnt-51.5" rr-50" (so called-
'76-81 CJ-7, CJ-8 ('81 only) frnt-51.5" rr-50" narrow axle)
'82-86 CJ-7 frnt-55.8" rr-55" (so called-
'82-85 Scrambler, CJ-8 frnt-55.8" rr-55" wide axle )
'84-87, 93 up Cherokee XJ 58"
'88-92 Cherokee XJ 57"
'86-92 Comanche, 57"
'87 up Wrangler, YJ 58"
'93 up Grand Cherokee, ZJ 58"
For quick ID reference, Dana puts the model # (28, 30, 44, 50, 60, 70, 80) raised in the casting of the center housing. All Dana axle assemblies are also marked by both a stamped # in one of the axle tubes and labeled by a metal tag attached to a cover bolt. Once this "Bill Of Material" is found, the # can be cross referenced in a DANA XGI and Manufacturer Catalog. The "Bill Of Material" will always start with '60' or '61' followed by four digits, a dash, and one or two final digits.
Example: of a "B.O.M. #": 610445-2 = Ford Model 60 FRONT 1994 - F350
Complete Bill Of Material information:
Bill of Material Number Manufacturer Model Front / Rear Application
603470 JEEP 60 REAR 1979 J20 PICKUP
603643 CHRY 60 FRONT 1979-80 D-600
603647 CHRY 60 REAR 1979 D-200 & W-200 H.D.
603651 CHRY 70 REAR 1979 M-300 & M-400 MOTOR HOME (2pc STD CASE)
603652 CHRY 70 REAR 1979 M-500 MOTOR HOME
603653 CHRY 70 REAR 1979-83 P-300
603683 JEEP 44 FRONT 1978-79 WAGONEER / CHEROKEE
603685 JEEP 44 FRONT 1978-79 J10, J20, HONCHO, CHEROKEE WIDE TRACK
603695 CHRY 70 REAR 1979 D-300/400 &W-300/400
603696 CHRY 70 REAR 1979 D-300 SWEPTLINE
603702 GM 60 REAR 1979 DRW G-VAN 146" WB - FULL FLOAT
603703 GM 70 REAR 1979 G-300 146" WB - 70B
603704 GM 70 REAR 1979 C-30 DUAL WHEEL - 70HD
603725 FORD 60 REAR 1979 F-250 CREW CAB - FULL FLOAT
603732 JEEP 30 FRONT 1978 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
603815 JEEP 44 REAR 1977-79 CHEROKEE CHIEF (STD TRANSFER CASE)
603816 JEEP 44 REAR 1977-79 WAGONEER & CHEROKEE (STD TRANSFER CASE)
603817 JEEP 44 REAR 1977-79 WAGONEER & CHEROKEE (QUADRA-TRAC TRANSFER CASE)
603818 JEEP 44 REAR 1977-79 CHEROKEE CHIEF QUADRA-TRAC
603820 JEEP 44 REAR 1977-80 POST OFFICE DISPATCHER
603831 CHRY 60 REAR 1979 RAIL MAINTENANCE
603841 CHRY 70 REAR 1979 WM 300
603884 GM 60 REAR 1979 DRW G-VAN 125" WB - FULL FLOAT
603901 FORD 60 REAR 1979 F-250 4X4 - FULL FLOAT
603909 FORD 70 REAR 1980 AMBULANCE - 70HD
603916 CHRY 70 REAR 1979-84 CB-400 & MB-400
603917 CHRY 60 REAR 1979 D-200 & BD-600
603918 CHRY 70 REAR 1979-84 CB-300 H.D. & MB-400 H.D.
603919 CHRY 60 REAR 1979 MD-300 DUAL WHEEL H.D.
603920 CHRY 60 REAR 1979 B-300 MAXIVAN H.D.
603925 FORD 61 REAR 1979 F-250 4X2 - FULL FLOAT
603926 FORD 60 REAR 1979 F-250 4X2 - FULL FLOAT
603929 GM 70 REAR 1979 P-300 MOTOR HOME - 70HD
603930 JEEP 60 REAR 1978-79 J20 PICKUP
603932 FORD 61 REAR 1979-80 E-250 - FULL FLOAT
603934 FORD 70 REAR 1979-80 E-350 VAN - 70HD
603935 FORD 70 REAR 1979 F-350 PICK-UP - 70HD
603936 FORD 70 REAR 1979-80 F-350 U-HAUL - 70B
603937 FORD 70 REAR 1979 F-350 CHASSIS - 70HD
603938 FORD 70 REAR 1979 E-350 CHASSIS - 70HD
603940 FORD 70 REAR 1979-80 E-350 CHASSIS - 70HD
603941 JEEP 44 REAR 1979 J10 & HONCHO TRUCK
603943 FORD 60 REAR 1980-81 F-250 3/4 TON 4X2, 4X4 PICK-UP - SEMI FLOAT
603944 FORD 61 REAR 1980 F-350 4X2 CHASSIS - FULL FLOAT
603946 FORD 61 REAR 1980-81 F-250 4X2 - SEMI FLOAT
603947 FORD 61 REAR 1980 F-350 4X2, 4X4 PICK-UP - FULL FLOAT
603949 FORD 70 REAR 1980 F-350 BIG DOOLEY - 70HD
603955 CHRY 70 REAR 1979-83 WM-300
603962 FORD 70 REAR 1980 F-350 CHASSIS - 70HD
603967 GM 44 REAR 1980 CORVETTE
603970 GM 70 REAR 1979 P-300 UPS - 70HD
603971 CHRY 60 REAR 1979-84 HIGH PERFORMANCE RACING AXLE (SEMI FLOAT)
603972 CHRY 60 REAR 1979-84 HIGH PERFORMANCE RACING AXLE (SEMI FLOAT)
603973 FORD 44 REAR 1979 F-100 & F-150
603980 JEEP 60 REAR 1980-81 1/2 J20 PICK-UP
603987 GM 70 REAR 1979 P-300 UPS M- 70HD
609389 CHRY 60 REAR 1980-88 1/2 RAIL MAINTENANCE/D-200 & D-600
603990 CHRY 60 REAR 1980-84 C-300 & B-300 MB-300 H.D.
603992 CHRY 60 REAR 1980-82 D-200 & W-200 H.D.
603993 CHRY 60 REAR 1980-84 MB-300 DUAL WHEEL H.D.
603994 CHRY 60 REAR 1980-88 1/2 B-300 MAXIVAN H.D.
603995 CHRY 70 REAR 1980-84 D-300/400 & W-300/400
603997 CHRY 70 REAR 1980-83 M-300 & M-400 MOTOR HOME
603998 CHRY 70 REAR 1980-83 M-500 MOTOR HOME
605000 GM 60 REAR 1980-82 DRW G-VAN 125" WB - FULL FLOAT
605001 GM 60 REAR 1980-82 DRW G-VAN 146" WB - FULL FLOAT
605002 GM 70 REAR 1980-82 G-300 146" WB - 70B
605003 GM 70 REAR 1980-81 C-30 DUAL WHEEL - 70HD
605004 GM 70 REAR 1980-81 P-300 MOTOR HOME - 70HD
605005 GM 70 REAR 1980-81 P-300 UPS - 70HD
605020 FORD 60 REAR 1980 1/2 E-250 - FULL FLOAT
605022 FORD 61 REAR 1981-83 E-350 DRW CHASSIS - FULL FLOAT
605030 FORD 61 REAR 1981 E-250 VAN - SEMI FLOAT
605031 FORD 60 REAR 1981-81 1/2 E-250 VAN - SEMI FLOAT
605038 FORD 70 REAR 1981-83 F-350 CHASSIS DSO DUAL WHEEL - 70HD
605039 FORD 61 REAR 1981-83 F-350 CHASSIS - FULL FLOAT
605040 FORD 61 REAR 1981-83 F-350 - FULL FLOAT
605042 FORD 70 REAR 1981-82 E350 CHASSIS - 70B
605043 GM 70 REAR 1985-89 P-300 UPS - 70HD
605044 FORD 70 REAR 1981-83 F-350 HEAVY DUTY CHASSIS - 70HD
605045 FORD 70 REAR 1981-83 F-350 DUAL WHEEL - 70HD
605053 FORD 70 REAR 1981-85 E-350 DSO - 70HD
605054 FORD 70 REAR 1981-83 F-350 U-HAUL - 70HD
605055 FORD 70 REAR 1981-82 F-350 DSO AMBULANCE - 70HD
605056 FORD 61 REAR 1981-83 3-350 SCHOOL BUS - FULL FLOAT
605057 FORD 70 REAR 1981-82 E-350 SCHOOL BUS - 70B
605062 GM 44 REAR 1981-83 CORVETTE
605064 FORD 61 REAR 1981 E-250 VAN - FULL FLOAT
605068 GM 70 REAR 1980-81 P-300 MOTOR HOME - 70HD
605079 JEEP 60 REAR 1982-85 J20 PICK-UP
605080 FORD 70 REAR 1981 1/2-83 E-350 DSO - 70B
605082 CHRY 60 REAR 1983-84 D-300 HD
605086 FORD 60 REAR 1982-83 F-250 - SEMI FLOAT
605087 FORD 61 REAR 1982 F-250 - SEMI FLOAT
605088 FORD 61 REAR 1982-83 E-250 VAN - SEMI FLOAT
605089 FORD 60 REAR 1982-83 E-250 VAN - SEMI FLOAT
605096 GM 70 REAR 1981 1/2 P-300 UPS - 70HD
605099 GM 70 REAR 1982-84 C/K-30 - 70HD
605101 FORD 70 REAR 1981 1/2-83 E-350 DSO - 70HD
605103 JEEP 44 REAR 1982-84 CJ10
605104 JEEP 60 REAR 1982 1/2-84 CJ10
605114 FORD 70 REAR 1982 1/2-83 E-350 DSO CHASSIS - 70U
605115 FORD 70 REAR 1983 E-350 DSO CHASSIS - 70U
605117 GM 70 REAR 1982 1/2-87 P-30 MOTOR HOME/DISC BRAKES - 70HD
605118 FORD 70 REAR 1982 1/2-83 F-350 DSO WIDE TRACK - 70HD
605132 GM 60 REAR 1983 DRW G-VAN 125" WB - FULL FLOAT
605133 GM 60 REAR 1983 DRW G-VAN 146" WB - FULL FLOAT
605134 GM 70 REAR 1983 G-300 146" WB - 70B
605138 FORD 70 REAR 1982 1/2-83 1/2 F-350 DSO AMBULANCE - 70HD
605139 FORD 70 REAR 1982 1/2-83 E-350 DSO - 70B
605143 FORD 70 REAR 1983 1/2 E-350 DSO - 70B
605145 FORD 60 REAR 1983 1/2 F-350 PICK-UP - SEMI FLOAT
605146 FORD 60 REAR 1983 1/2 F-350 CHASSIS - SEMI FLOAT
605154 FORD 61 REAR 1983 1/2 F-350 PICK-UP - SEMI FLOAT
605156 FORD 61 REAR 1983 1/2 F-350 CHASSIS - SEMI FLOAT
605158 CHRY 70 REAR 1985-90 1/2 ISREAL AIRCRAFT
605169 FORD 60 REAR 1983 1/2-85 F-250 - SEMI FLOAT
605170 FORD 70 REAR 1984-85 F-350 6 WHEELER - 70HD
605172 GM 36 REAR 1984 CORVETTE
605175 FORD 70 REAR 1983 1/2 F-350 CHASSIS - 70U
605176 FORD 70 REAR 1983 1/2-85 F-350 HEAVY DUTY CHASSIS - 70HD
605178 FORD 61 REAR 1983 1/2 E-250 VAN - SEMI FLOAT
605179 FORD 60 REAR 1983 1/2 E-250 VAN - SEMI FLOAT
605180 GM 36 REAR 1984 CORVETTE
605192 CHRY 70 REAR 1984-85 D-300/D-450 SWEPTLINE & D-350 & W-350
605196 JEEP 60 REAR 1985 AM 720
605197 FORD 61 REAR 1984-85 F-350 - FULL FLOAT
605198 FORD 61 REAR 1984-85 F-350 & F-350 CHASSIS
605200 GM 60 REAR 1985-86 DRW G-VAN 125" WB - FULL FLOAT
605201 GM 60 REAR 1985-89 DRW G-VAN 146" WB - FULL FLOAT
605202 GM 70 REAR 1984-89 DRW G-VAN 146" WB - 70U
605203 GM 70 REAR 1984-86 C/K-30 & R/V-30 - 70HD
605204 FORD 70 REAR 1983 1/2-85 F-350 PICK-UP - 70U
605205 FORD 70 REAR 1983 1/2-85 F-350 CHASSIS - 70U
605206 FORD 70 REAR 1983 1/2 F-350 U-HAUL - 70U
605207 FORD 70 REAR 1983 1/2-85 F-350 DSO AMBULANCE - 70HD
605208 FORD 70 REAR 1984-85 F-350 CHASSIS - 70U
605211 FORD 60 REAR 1984-85 E-250 VAN - SEMI FLOAT
605212 FORD 61 REAR 1984-85 E-350 VAN SRW - FULL FLOAT
605213 FORD 70 REAR 1984-85 E-350 CHASSIS - 70U
605214 CHRY 70 REAR 1985 D-300 & D-400 & D-700
605215 CHRY 70 REAR 1985 D-300
605218 GM 44 REAR 1984-85 F-CAR
605220 GM 44 REAR 1985-87 CORVETTE
605222 CHRY 60 REAR 1985-88 1/2 B-300 (VAN)
605224 CHRY 60 REAR 1985-85 1/2 D-200 & BD-600
605225 CHRY 60 REAR 1985-88 1/2 D-200 HD & D-300 H.D.
605235 CHRY 70 REAR 1985-88 1/2 FRONT SECTION MOTOR HOME
605236 JEEP 44 REAR 1985 CJ10
605237 JEEP 60 REAR 1985 CJ10
605239 GM 36 REAR 1984-86 CORVETTE
605242 JEEP 70 REAR 1985 CJ 10A MILITARY
605244 FORD 61 REAR 1985 F-350 - FULL FLOAT
605246 FORD 70 REAR 1985 F-350 CHASSIS - 70U
605247 FORD 70 REAR 1985 F-350 CHASSIS - 70U
605248 FORD 70 REAR 1985 F-350 CHASSIS - 70U
605249 FORD 70 REAR 1985 F-350 HEAVY DUTY CHASSIS - 70HD
605250 FORD 70 REAR 1985 F-350 6 WHEELER - 70HD
605251 FORD 60 REAR 1985 E-250 VAN SRW - SEMI FLOAT
605252 FORD 61 REAR 1985-86 E-350 VAN - FULL FLOAT
605253 FORD 70 REAR 1985-86 E-350 CHASSIS - 70U
605254 FORD 60 REAR 1985 F-250 - SEMI FLOAT
605255 FORD 70 REAR 1985-87 F-350 DSO AMBULANCE - 70HD
605260 GM 36 REAR 1985-87 CORVETTE
605267 FORD 30 REAR 1985 1A AEROSTAR VAN
605268 GM 60 REAR 1986-89 DRW G-VAN 125" WB - FULL FLOAT
605269 CHRY 70 REAR 1985 1/2 D-300 & D-400 & D-500 & D-600
605270 CHRY 70 REAR 1985 1/0 D-300 & D-400 & D-500 & D-600
605273 FORD 30 REAR 1986-88 1A AEROSTAR VAN
605285 JEEP 44 REAR 1986 GRAND WAGONEER
605286 JEEP 44 REAR 1986 J10 PICKUP
605287 JEEP 44 REAR 1986 XJ METRIC TON TRUCK
605289 JEEP 44 REAR 1986 CJ7
605290 JEEP 35 REAR 1986 XJ UTILITY
605291 JEEP 60 REAR 1986-88 J20 PICKUP
605292 JEEP 35 REAR 1986 XJ TRUCK
605293 JEEP 35 REAR 1986 XJ UTILITY
605294 JEEP 35 REAR 1986 XJ PICKUP
605295 JEEP 35 REAR 1987-89 YJ
605298 FORD 60 REAR 1986-88 E-250 VAN SRW - SEMU FLOAT
605299 FORD 61 REAR 1987 E-350 VAN - FULL FLOAT
605300 FORD 70 REAR 1987-88 E-350 CHASSIS - DRW - 70U
605302 GM 70 REAR 1988-90 SRW G-VAN 30 - 70-3HD
605303 FORD 80 REAR 1988 F-350 SUPER DUTY
605305 GM 70 REAR 1987 SRW C-30 - 70-3HD
605370 GM 70 REAR 1988-89 DRW G-VAN 30 - 70-3HD
605311 CHRY 70 REAR 1987-90 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
605312 CHRY 70 REAR 1989-90 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
605313 CHRY 70 REAR 1987-90 D-300 & D-700 W/ABS
605315 JEEP 35 REAR 1985 1/2 XJ UTILITY
605316 JEEP 35 REAR 1985 1/2 XJ UTILITY
605321 GM 36 REAR 1988-90 CORVETTE
605322 GM 44 REAR 1989 1/2-90 CORVETTE
605323 JEEP 35 REAR 1987-89 XJ UTILITY
605324 JEEP 35 REAR 1987-89 XJ PICKUP
605325 JEEP 44 REAR 1987-93 1/2 XJ METRIC TON TRUCK, XJ HD TRUCK
605329 JEEP 44 REAR 1987-92 GRAND WAGONEER
605330 JEEP 44 REAR 1987-88 J10 PICKUP
605331 GM 70 REAR 1987-91 1/2 R/V-30 - 70HD
605337 FORD 70 REAR 1988 1/2-89 E-350 U-HAUL CHASSIS - 70HD
605339 JEEP 44 REAR 1988 1/2-96 1/2 YJ
605342 JEEP 44 REAR 1987-87 1/2 XJ UTILITY
605344 FORD 70 REAR 1987 1/2 E-350 CHASSIS - DRW - 70HD
605345 GM 70 REAR 1987 1/2 SRW C-30 - 70-3HD
605346 GM 70 REAR 1987 1/2-89 SRW K-30 - 70-3HD
605351 JEEP 35 REAR 1988-89 XJ UTILITY, TRAILER TOW, ABS
605352 FORD 70 REAR 1987 1/2 E-350 CHASSIS - DRW - 70U
605355 FORD 60 REAR 1988 E-350 VAN SRW - FULL FLOAT
605361 GM 70 REAR 1988 P-30 MOTOR HOME/DISC BRAKES - 70HD
605363 GM 70 REAR 1988-89 P-30 MOTOR HOME/DISC BRAKES - 70HD
605365 GM 44 REAR 1988-89 CORVETTE
605368 CHRY 60 REAR 1989-90 1/2 D-300 & D-700 H.D. W/ABS
605370 CHRY 60 REAR 1989-93 1/2 D-200 H.D. & D-600 H.D. W/ABS
605371 CHRY 60 REAR 1989-93 1/2 D-200 H.D. & D-600 H.D. W/ABS
605373 CHRY 70 REAR 1989-90 D-300 & D-700 W/ABS
605386 CHRY 70 REAR 1988-90 1/2 FRONT SECTION MOTOR HOME
605387 JEEP 35 REAR 1988 1/2-89 XJ UTILITY, I-6 AUTOMATIC
605389 JEEP 35 REAR 1988 1/2-89 XJ UTILITY, TRAILER TOW
605391 GM 70 REAR 1988-89 P-30 MOTOR HOME/DISC BRAKES - 70HD
605397 GM 70 REAR 1988-89 DRW C/K-30 - 70-3HD
605400 FORD 80 REAR 1989 F-350 SUPER DUTY
605403 GM 60 REAR 1990 DRW G-VAN 146" WB - FULL FLOAT
605405 GM 60 REAR 1990 DRW G-VAN 125" WB - FULL FLOAT
605407 CHRY 70 REAR 1989-90 D-300
605408 CHRY 70 REAR 1989 D-300 WIDE TRACK W/ABS
605412 FORD 70 REAR 1989 E-350 CHASSIS - DRW - 70U
605413 FORD 60 REAR 1989 E-350 VAN SRW - FULL FLOAT
605414 FORD 60 REAR 1989 E-250 VAN SRW - SEMI FLOAT
605415 GM 70 REAR 1989 1/2 P-300 UPS - 70HD
605416 JEEP 35 REAR 1990-90 1/2 XJ UTILITY
605417 GM 44 REAR 1990-90 1/2 CORVETTE
605418 GM 70 REAR 1989 1/2 G-VAN EXTENDED - 70-3HD
605419 FORD 60 REAR 1990-91 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
605420 FORD 60 REAR 1990-91 1/2 E-250 VAN SRW - FULL FLOAT - ABS
605421 FORD 70 REAR 1990-91 1/2 E-350 CHASSIS - DRW - ABS - 70U
605423 JEEP 35 REAR 1990-90 1/2 YJ
605425 JEEP 35 REAR 1990-90 1/2 MJ PICKUP
605427 JEEP 35 REAR 1990-91 1/2 XJ UTILITY, TRAILER TOW, ABS
605434 FORD 30 REAR 1989 1/2 1A AEROSTAR VAN
605437 FORD 70 REAR 1989-90 1/2 E-350 MOTOR HOME - 70U
605438 FORD 70 REAR 1989-90 E-350 MOTOR HOME - 70HD
605440 CHRY 60 REAR 1989-94 1/2 B-300 H.D. W/ABS
605441 CHRY 60 REAR 1989 B-300 MAXIVAN H.D.
605443 JEEP 35 REAR 1990-90 1/2 XJ UTILITY, I-6 AUTOMATIC
605444 JEEP 35 REAR 1990-90 1/2 XJ UTILITY, TRAILER TOW
605445 FORD 80 REAR 1990-91 1/2 F-350 SUPER DUTY
605449 GM 70 REAR 1990-91 1/2 SRW G-VAN 30 - 70-3HD
605452 GM 70 REAR 1990 DRW G-VAN 146" WB - 70U
605453 GM 70 REAR 1990 DRW G-VAN 30 - 70-3HD
605454 GM 70 REAR 1990-91 1/2 G-VAN EXTENDED - 70-3HD
605455 JEEP 35 REAR 1988-89 XJ PICKUP
605456 GM 70 REAR 1989 1/2-90 P-30 MOTOR HOME/DISC BRAKES - 70HD
605457 GM 70 REAR 1989 1/2-90 P-30 MOTOR HOME/DISC BRAKES - 70HD
605461 FORD 80 REAR 1992-93 1/2 F-450 CHASSIS-DRW-FULLFLOAT
605470 GM 70 REAR 1990 P-300 UPS - 70HD
605471 FORD 70 REAR 1990-91 1/2 E-350 MOTOR HOME - ABS - 70HD
605475 JEEP 35 REAR 1993-94 ZJ ABS
605480 FORD 70 REAR 1990-91 1/2 E-350 U-HAUL CHASSIS - ABS - 70HD
605483 JEEP 35 REAR 1990-92 1/2 XJ UTILITY
605484 JEEP 35 REAR 1990-92 1/2 XJ UTILITY, I-6 AUTOMATIC
605485 JEEP 35 REAR 1990-92 1/2 XJ UTILITY, TRAILER TOW
605487 FORD 60 REAR 1992-93 1/2 E-350 VAN SARW - FULL FLOAT
605488 FORD 70 REAR 1992 E-350 CHASSIS - DRW - ABS - 70U
605489 CHRY 70 REAR 1990 1/2 AIR FORCE TOW VEHICLE W/ABS
605490 GM 36 REAR 1990 1/2-96 1/2 CORVETTE
605491 GM 44 REAR 1990-96 1/2 CORVETTE
605492 GM 44 REAR 1990 1/2 CORVETTE
605493 GM 70 REAR 1990 1/2-92 1/2 P-300 UPS - 70HD
605494 GM 70 REAR 1991-93 1/2 70HD
605495 GM 60 REAR 1990 1/2-91 1/2 DRW G-VAN 146" WB - FULL FLOAT
605496 GM 60 REAR 1990 1/2-91 1/2 DRW G-VAN 125" WB - FULL FLOAT
605497 GM 70 REAR 1990 1/2-91 1/2 DRW G-VAN 146" WB - 70U
605498 GM 70 REAR 1990 1/2-91 1/2 DRW G-VAN 30 - 70-3HD
605499 GM 80 REAR 1992 MOTOR HOME/DISC BRAKES - 80
605500 JEEP 35 REAR 1991-93 1/2 MJ PICKUP
605501 FORD 70 REAR 1991-91 1/2 CONTINENTAL BAKERY CHASSIS - ABS - 70U
605502 JEEP 35 REAR 1991-93 1/2 YJ
605507 JEEP 35 REAR 1993-94 ZJ T/TOW, ABS
605508 CHRY 70 REAR 1991-93 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
605509 CHRY 70 REAR 1991-93 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
605510 CHRY 70 REAR 1991-93 1/2 D-300 & D-700 W/ABS
605511 CHRY 70 REAR 1991-93 1/2 D-300 & D-700 W/ABS
605512 CHRY 70 REAR 1991-93 1/2 D-300 WIDE TRACK W/ABS
605513 CHRY 70 REAR 1987-93 D-300 WIDE TRACK W/ABS
605514 CHRY 70 REAR 1991-93 1/2 AIR FORCE TOW VEHICLE W/ABS
605516 CHRY 60 REAR 1991-94 B-300 MAXIVAN W/ABS
605517 CHRY 60 REAR 1991-95 1/2 D-300 & D-700 H.D. W/ABS
605518 FORD 70 REAR 1990-91 1/2 UPS CHASSIS - ABS - 70U
605522 CHRY 70 REAR 1991-93 1/2 D-300 & D-400 & D-500 & D-600 & D-700 W/ABS
605524 GM 80 REAR 1992 1/2-93 1/2 GMT 455 - 80
605525 JEEP 35 REAR 1992-93 1/2 YJ ABS
605526 GM 80 REAR 1992 1/2-93 1/2 P-TRUCK - 80
605527 GM 80 REAR 1992 1/2-93 1/2 P-TRUCK - 80
605528 JEEP 35 REAR 1993-93 1/2 YJ ABS
605529 CHRY 44 REAR 1993 1/2 VIPER
605534 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
605535 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
605536 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
605537 FORD 70 REAR 1992 CONTINENTAL BAKERY CHASSIS - ABS - 70U
605538 FORD 70 REAR 1992-93 1/2 E-350 MOTOR HOME - ABS - 70HD
605539 FORD 70 REAR 1992-93 1/2 E-350 U-HAUL CHASSIS - ABS - 70HD
605540 FORD 70 REAR 1992-92 1/2 UPS CHASSIS - ABS - 70U
605541 JEEP 35 REAR 1992-93 1/2 YJ ABS
605547 CHRY 70 REAR 1991-93 1/2 D-300 & D-400 & D-500 & D-600 & D-700 W/ABS
605556 FORD 60 REAR 1992 E-250 VAN SRW - SEMI FLOAT - ABS
605558 GM 44 REAR 1992 1/2-94 F-CAR
605559 GM 70 REAR 1993-94 P-300 UPS - 70HD
605564 JEEP 35 REAR 1992-93 1/2 YJ ABS
605567 FORD 70 REAR 1992 1/2-93 1/2 E-350 CHASSIS - DRW - ABS - 70U
605569 FORD 60 REAR 1993-95 E-250 VAN SRW - SEMI FLOAT
605575 GM 80 REAR 1993-93 1/2 GMT 455 - 80
605578 FORD 70 REAR 1992 1/2-93 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
605579 JEEP 35 REAR 1993-94 XJ UTILITY ABS
605583 FORD 70 REAR 1992 1/2-93 1/2 CONTINENTAL BAKERY CHASSIS - ABS - 70U
605584 FORD 70 REAR 1992 1/2-93 1/2 UPS CHASSIS - ABS - 70U
605585 CHRY 60 REAR 1994-95 1/2 D2500
605586 CHRY 60 REAR 1994-95 1/2 W2500
605588 CHRY 70 REAR 1994-95 1/2 W2500
605590 CHRY 70 REAR 1994-95 1/2 D2500
605592 CHRY 80 REAR 1994-95 1/2 D3500
605593 CHRY 80 REAR 1994-95 1/2 D3500
605594 CHRY 80 REAR 1994-95 1/2 D/W3500
605595 CHRY 80 REAR 1994-95 1/2 D2500
605596 CHRY 80 REAR 1994-95 1/2 W2500
605601 GM 80 REAR 1993-96 1/2 MOTOR HOME/DISC BRAKES - 80
605602 JEEP 35 REAR 1994 ZJ ABS
605607 JEEP 35 REAR 1994 ZJ ABS
605608 FORD 70 REAR 1993 1/2-94 E-350 CHASSIS - DRW - ABS - 70U
605609 FORD 70 REAR 1993 1/2-94 E-350 MOTOR HOME - ABS - 70HD
605623 FORD 60 REAR 1993-94 E-250 VAN SRW - SEMI FLOAT - ABS
605624 FORD 60 REAR 1993 1/2-94 E-350 VAN SRW - FULL FLOAT
605632 FORD 80 REAR 1993-94 1/2 F-450 CHASSIS-DRW-FULL FLOAT
605633 CHRY 60 REAR 1994-95 1/2 D2500
605634 CHRY 60 REAR 1994-95 1/2 W2500
605638 GM 80 REAR 1994-95 1/2 W2500
605638 GM 80 REAR 1994 1/2-95 1/2 P-TRUCK - 80
605639 FORD 60 REAR 1994-95 E-350 VAN SRW - FULL FLOAT
605640 FORD 70 REAR 1994-94 1/2 E-350 CHASSIS - 70U
605643 GM 80 REAR 1993 1/2-95 1/2 P-TRUCK - 80
605644 GM 80 REAR 1993-95 1/2 P-TRUCK - 80
605648 CHRY 44 REAR 1994-95 1/2 VIPER
605649 GM 80 REAR 1995-95 1/2 GMT 455 - 80
605655 JEEP 35 REAR 1994 XJ UTILITY, STD
605656 JEEP 35 REAR 1994 XJ UTILITY
605657 JEEP 35 REAR 1994 XJ UTILITY ABS
605658 JEEP 35 REAR 1994 XJ UTILITY ABS
605659 JEEP 35 REAR 1994 XJ UTILITY ABS
605660 JEEP 35 REAR 1994 XJ UTILITY
605661 JEEP 35 REAR 1994-96 YJ/TJ
605662 JEEP 35 REAR 1994-96 YJ/TJ ABS
605665 FORD 70 REAR 1993 1/2-94 E-350 CHASSIS - DRW - ABS - 70U
605666 FORD 70 REAR 1993 1/2-94 E-350 CHASSIS - DRW - ABS - 70U
605667 FORD 70 REAR 1993 1/2-94 1/2 E-350 CHASSIS - DRW - ABS - 70U
605669 FORD 70 REAR 1993 1/2-94 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
605670 FORD 60 REAR 1994-94 1/2 E-350 VAN SRW - FULL FLOAT
605671 FORD 70 REAR 1994 E-350 CHASSIS - DRW - ABS - 70U
605672 FORD 70 REAR 1994-94 1/2 E-350 MOTOR HOME - ABS - 70HD
605673 FORD 70 REAR 1994-94 1/2 E-350 CHASSIS - DRW - ABS - 70U
605674 FORD 70 REAR 1994-94 1/2 E-350 SRW CUTAWAY, WIDETRACK 70 2U
605675 FORD 70 REAR 1994-94 1/2 E-350 SRW CUTAWAY, WIDETRACK 70 2U
605684 FORD 60 REAR 1995-96 E-350 VAN SRW - FULL FLOAT
605685 FORD 60 REAR 1995-96 E-350 VAN SRW - FULL FLOAT
605686 FORD 70 REAR 1995-95 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
605687 FORD 70 REAR 1995-95 1/2 E-350 CHASSIS - DRW - 70U
605688 FORD 70 REAR 1995-95 1/2 E-350 MOTOR HOME - 70HD
605689 FORD 70 REAR 1995-95 1/2 E-350 CHASSIS - DRW - 70U
605690 FORD 70 REAR 1995-95 1/2 E-350 MOTOR HOME - ABS - 70HD
605691 GM 80 REAR 1995-95 1/2 GMT 455 - 80
605692 FORD 70 REAR 1994 E-350 CHASSIS - DRW - 70HD
605693 FORD 70 REAR 1994 E-350 CHASSIS - DRW - 70HD
605695 GM 80 REAR 1994 1/2-95 1/2 GMT 455 - 80
605700 FORD 60 REAR 1995-96 E-350 VAN SRW - SEMI FLOAT - ABS
605706 JEEP 35 REAR 1995-96 ZJ ABS
605707 JEEP 35 REAR 1995-96 ZJ ABS
605710 CHRY 60 REAR 1994 1/2-97 1/2 B-300 VAN W/ABS
605711 CHRY 60 REAR 1994 1/2-97 1/2 B-300 VAN W/ABS
605712 GM 80 REAR 1994 1/2-95 1/2 P-TRUCK - 80
605713 FORD 60 REAR 1994 1/2 E-350 VAN SRW - FULL FLOAT - ABS
605714 FORD 70 REAR 1994 1/2-95 E-350 CHASSIS - DRW - 70HD
605715 FORD 70 REAR 1994 1/2-95 1/2 E-350 MOTOR HOME - ABS - 70HD
605717 FORD 80 REAR 1995-95 1/2 F-450 CHASSIS-DRW-FULL FLOAT
605718 CHRY 80 REAR 1995-97 SWEPTLINE VEHICLE
605719 GM 80 REAR 1995-95 1/2 MOTOR HOME/DISC BRAKES - 80
605722 CHRY 70 REAR 1995-95 1/2 AIR FORCE TOW VEHICLE W/ABS
605723 CHRY 70 REAR 1995-95 1/2 D2500 AIR FORCE TOW VEHICLE ABS
605725 JEEP 35 REAR 1994 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605727 JEEP 35 REAR 19950-96 1/2 XJ UTILITY ABS
605728 JEEP 35 REAR 1995-96 XJ UTILITY, STD
605729 JEEP 35 REAR 1995-96 XJ UTILITY
605730 JEEP 35 REAR 1995-96 1/2 XJ UTILITY ABS
605731 JEEP 35 REAR 1995-96 XJ UTILITY ABS
605732 JEEP 35 REAR 1995-96 1/2 XJ UTILITY ABS
605733 JEEP 35 REAR 1995-96 1/2 XJ UTILITY
605735 JEEP 44 REAR 1996-97 ZJ ABS
605745 GM 80 REAR 1994 1/2-95 1/2 P-TRUCK - 80
605746 JEEP 35 REAR 1996 1/2 YJ/TJ ABS
605747 JEEP 35 REAR 1996 1/2 YJ/TJ (NEW MODEL NUMBER 194)
605750 FORD 60 REAR 1995-97 E-250 VAN SRW - SEMI FLOAT - ABS
605752 CHRY 44 REAR 1996-97 VIPER
605753 GM 80 REAR 1995 1/2-95 1/2 GMT 455 - 80
605767 GM 80 REAR 1995-95 1/2 P-TRUCK - 80
605775 JEEP 35 REAR 1996-96 1/2 XJ DIESEL
605776 JEEP 35 REAR 1996-96 1/2 XJ DIESEL
605783 GM 80 REAR 1995-95 1/2 P-TRUCK - 80
605784 CHRY 60 REAR 1996-96 1/2 D2500
605787 CHRY 70 REAR 1996-96 1/2 D2500
605788 CHRY 80 REAR 1996-96 1/2 D3500
605789 CHRY 80 REAR 1996-96 1/2 D3500
605790 CHRY 80 REAR 1996-96 1/2 D/W3500
605791 CHRY 80 REAR 1996-96 1/2 D2500
605792 CHRY 80 REAR 1996 1/2 D2500
605793 CHRY 60 REAR 1996-96 1/2 D2500
605794 CHRY 60 REAR 1996 1/2 W2500
605797 JEEP 35 REAR 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 194)
605798 JEEP 35 REAR 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 194)
605807 FORD 80 REAR 1997-98 E-350 DRW CHASSIS - FULL FLOAT
605810 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
605811 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
605812 GM 80 REAR 1996-98 P-TRUCK - 80
605813 GM 80 REAR 1996 1/2 P-TRUCK - 80
605814 GM 80 REAR 1996-98 P-TRUCK - 80
605815 GM 80 REAR 1996-98 P-TRUCK - 80
605816 GM 80 REAR 1996-98 P-TRUCK - 80
605817 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
605818 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
605831 FORD 80 REAR 1996-98 F-450 CHASSIS-DRW-FULL FLOAT
605834 FORD 80 REAR 1996 E-350 DRW CHASSIS - FULL FLOAT
605838 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
605839 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
605840 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
605841 FORD 60 REAR 1996-96 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
605842 FORD 60 REAR 1996-96 1/2 E-350 VAN SRW - FULL FLOAT
605843 FORD 60 REAR 1996 E-350 VAN SRW - FULL FLOAT - ABS
605844 FORD 70 REAR 1995-95 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
605845 FORD 70 REAR 1995-95 1/2 E-350 CHASSIS - DRW - 70U
605846 FORD 70 REAR 1996-97 E-350 MOTOR HOME - ABS - 70HD
605847 FORD 70 REAR 1996-97 E-350 CHASSIS - DRW - ABS - 70U
605848 FORD 70 REAR 1996-97 E-350 MOTOR HOME - ABS - 70HD
605849 JEEP 44 REAR 1997 TJ NON ABS (NEW MODEL NUMBER 216)
605858 GM 80 REAR 1996 1/2 GMT 455 - 80
605859 FORD 60 REAR 1996-97 E-250 VAN SRW - SEMI FLOAT - ABS
605860 FORD 70 REAR 1996-97 E-350 CHASSIS - DRW - ABS - 70U
605861 FORD 70 REAR 1996-97 E-650 CHASSIS - DRW - ABS - 70U
605862 FORD 70 REAR 1996-97 E-350 CHASSIS - DRW - ABS - 70U
605867 GM 80 REAR 1996-99 GMT 455 - 80
605868 GM 80 REAR 1996-98 GMT 455 - 80
605869 GM 80 REAR 1996-98 GMT 455 - 80
605879 CHRY 70 REAR 1996-97 1/2 W2500 AIR FORCE TOW VEHICLE ABS
605880 CHRY 70 REAR 1996-97 1/2 W2500 AIR FORCE TOW VEHICLE ABS
605893 JEEP 35 REAR 1996 1/2 XJ UTILITY, STD (NEW MODEL NUMBER 194)
605894 JEEP 35 REAR 1996 1/2 XJ UTILITY (NEW MODEL NUMBER 194)
605895 JEEP 35 REAR 1996 1/2 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605896 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
605898 CHRY 60 REAR 1997-97 1/2 D2500
605902 CHRY 80 REAR 1997 D3500
605903 CHRY 80 REAR 1997 D3500
605904 CHRY 80 REAR 1997 D/W3500
605905 CHRY 80 REAR 1997 D2500
605906 CHRY 80 REAR 1997 D2500
605907 CHRY 60 REAR 1997-97 1/2 D2500
605908 CHRY 60 REAR 1997-97 1/2 W2500
605909 JEEP 35 REAR 1996 1/2 XJ DIESEL, ABS (NEW MODEL NUMBER 194)
605913 JEEP 35 REAR 1997 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605914 JEEP 35 REAR 1997 XJ UTILITY ABS (NEW MODEL NUMBER 194)
605916 JEEP 35 REAR 1997 XJ DIESEL, NON ABS (NEW MODEL NUMBER 194)
605918 JEEP 35 REAR 1997 XJ UTILITY, ABS (NEW MODEL NUMBER 194)
605919 JEEP 35 REAR 1997 XJ DIESEL ABS (NEW MODEL NUMBER 194)
605924 FORD 80 REAR 1998 1/2-99 F-350 CHASSIS-DRW-FULL FLOAT
605925 FORD 80 REAR 1998 1/2-99 F-450 CHASSIS-DRW-FULL FLOAT
605926 FORD 80 REAR 1998 1/2-99 F-350 PICK-UP DRW-FULL FLOAT
605933 FORD 60 REAR 1996 1/2-97 E-250 VAN SRW - SEMI FLOAT
605934 FORD 60 REAR 1996 1/2 E-350 VAN SRW - FULL FLOAT
605935 FORD 60 REAR 1996 1/2 E-350 VAN SRW - FULL FLOAT
605942 FORD 80 REAR 1998 1/2-99 F-350 CHASSIS-DRW-FULL FLOAT
605944 FORD 80 REAR 199 1/2 F-450 MOTOR HOME - DRW - FULL FLOAT
605947 FORD 60 REAR 1997 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
605948 FORD 60 REAR 1997 1/2 E-350 VAN SRW - FULL FLOAT
605949 FORD 60 REAR 1997 1/2 E-350 VAN SRW - FULL FLOAT
605950 FORD 70 REAR 1997 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
605951 FORD 70 REAR 1997 E-350 CHASSIS - DRW - ABS - 70U
605952 JEEP 44 REAR 1997 TJ RHD, NON ABS (NEW MODEL NUMBER 216)
605956 JEEP 35 REAR 1997 TJ ABS (NEW MODEL NUMBER 194)
605957 JEEP 35 REAR 1997 TJ NON ABS (NEW MODEL NUMBER 194)
605960 JEEP 35 REAR 1997 ZJ ABS (NEW MODEL NUMBER 194)
605961 JEEP 35 REAR 1997 ZJ ABS (NEW MODEL NUMBER 194)
605962 JEEP 44 REAR 1997 ZJ ABS (NEW MODEL NUMBER 216)
605975 CHRY 80 REAR 1997 1/2 D3500
605976 CHRY 80 REAR 1997 1/2 D3500
605977 CHRY 80 REAR 1997 1/2 D/W3500
605978 CHRY 60 REAR 1998-98 1/2 D2500
605982 CHRY 80 REAR 1998-98 1/2 D3500
605983 CHRY 80 REAR 1998-98 1/2 D3500
605984 CHRY 80 REAR 1998-98 1/2 D/W3500
605985 CHRY 80 REAR 1998-98 1/2 D2500
605987 CHRY 60 REAR 1998-98 1/2 D2500
605988 CHRY 60 REAR 1998-98 1/2 W2500
606014 CHRY 44 REAR 1998-98 1/2 VIPER
606017 FORD 60 REAR 1998-98 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
606020 FORD 70 REAR 1998-98 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70U
606021 FORD 70 REAR 1998-98 1/2 E-350 CHASSIS - DRW - ABS - 70U
606022 FORD 60 REAR 1999 E-350 VAN SRW - SEMI FLOAT - ABS
606026 FORD 70 REAR 1999 E-350 CUTAWAY SRW OR CHASSIS DRW OPTION
606028 FORD 70 REAR 1997 1/2-98 1/2 E-350 CHASSIS - DRW
606029 FORD 60 REAR 1997 1/2-98 E-250 VAN SRW - SEMI FLOAT - ABS
606040 GM 80 REAR 1997-99 P-TRUCK - 80
606041 GM 80 REAR 1997-99 P-TRUCK - 80
606042 GM 80 REAR 1997-99 P-TRUCK - 80
606043 GM 80 REAR 1997-99 P-TRUCK - 80
606049 FORD 60 REAR 1998 E-350 VAN SRW - FULL FLOAT - ABS
606050 FORD 60 REAR 1998 E-350 VAN SRW - FULL FLOAT - ABS
606054 CHRY 60 REAR 1997 1/2 W2500
606056 CHRY 80 REAR 1997 1/2 W2500
606058 CHRY 60 REAR 1998-98 1/2 B-300 VAN W/ABS
606059 CHRY 60 REAR 1998-98 1/2 B-300 VAN W/ABS
606062 CHRY 60 REAR 1998-98 1/2 W2500
606064 CHRY 80 REAR 1998-98 1/2 W2500
606073 GM 80 REAR 1998 1/2-99 GMT 455 - 80
606074 GM 80 REAR 1998 1/2-99 GMT 455 - 80
606076 FORD 80 REAR 1998 1/2 E-350 SUPER DUTY - DRW - FULL FLOAT
606102 FORD 60 REAR 1998 1/2-99 E-250 VAN SRW - SEMI FLOAT - ABS
606109 FORD 60 REAR 1999 E-350 VAN SRW - FULL FLOAT - ABS
606123 GM 80 REAR 1998 1/2-99 GMT 455 - 80
606144 FORD 80 REAR 1999 E-350 SUPER DUTY - DRW - FULL FLOAT
606145 FORD 70 REAR 1999-99 1/2 E-350 CHASSIS - DRW
606158 FORD 70 REAR 1998 1/2-99 E-350 CUTAWAY OR CHASSIS DRW OPTION
606159 FORD 70 REAR 1998 1/2 E-350 DRW CHASSIS - FULL FLOAT
606161 FORD 60 REAR 1998 1/2-99 E-250 VAN SRW - SEMI FLOAT - ABS
606162 FORD 60 REAR 1998 1/2-99 E350 VAN SRW - FULL FLOAT - ABS
606188 FORD 60 REAR 1999 1/2 E-250 VAN SRW
606189 FORD 70 REAR 1999 1/2 E-350 CUTAWAY SRW OR CHASSIS DRW OPTION
606192 FORD 60 REAR 1999 1/2 E-250 VAN SRW
606199 FORD 60 REAR 1999-99 1/2 E-350 CHASSIS - DRW
606201 GM 80 REAR 1999 1/2 P-TRUCK - 80
606202 GM 80 REAR 1999 1/2 P-TRUCK - 80
606203 GM 80 REAR 1999 1/2 P-TRUCK - 80
606204 GM 80 REAR 1999 1/2 P-TRUCK - 80 WIDETRACK
606211 GM 80 REAR 1999 1/2 GMT 455 - 80
606212 GM 80 REAR 1999 1/2 GMT 455 - 80 WIDETRACK
606213 GM 80 REAR 1999 1/2 GMT 455 - 80
606214 GM 80 REAR 1999 1/2 GMT 455 - 80
610023 FORD 60 FRONT 1978-79 F-250 & F-350 (SNOW FIGHTER)
610027 CHRY 44 FRONT 1979 W-100
610028 CHRY 44 FRONT 1979 W-200
610053 JEEP 30 FRONT 1979 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610054 GM 44 FRONT 1979 BLAZER & K-10
610055 GM 44 FRONT 1978-79 K-20
610056 GM 44 FRONT 1979 K-20
610057 GM 60 FRONT 1979-80 K-30
610062 FORD 44 FRONT 1980 BRONCO II & F-150 PICK-UP WITH PART TIME TRANSFER CASE
610063 FORD 44 FRONT 1980 F-250 3/4-TON PICK-UP (PART TIME TRANSFER CASE)
610064 FORD 50 FRONT 1980 F-350
610066 FORD 44 FRONT 1979 F-150 1/2 TON PICK-UP (FULL TIME TRANSFER CASE)
610067 FORD 44 FRONT 1979 F-150 1/2 TON PICK-UP (PART TIME TRANSFER CASE)
610068 FORD 44 FRONT 1979 F-150 SUPER CAB
610069 FORD 44 FRONT 1979 F-250
610076 CHRY 44 FRONT 1980 W-100
610077 CHRY 44 FRONT 1980 W-200
610078 JEEP 30 FRONT 1980-81 IFS - EAGLE - NON-DISCONNECT
610079 GM 44 FRONT 1980 K-20
610080 GM 44 FRONT 1979-80 K-20
610081 GM 44 FRONT 1979-80 K-20
610084 CHRY 44 FRONT 1980-83 W-200
610086 JEEP 30 FRONT 1980 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610089 JEEP 44 FRONT 1980 J10, J20, WIDE TRACK CHEROKEE
610090 JEEP 44 FRONT 1980 WAGONEER / CHEROKEE
610127 CHRY 44 FRONT 1981-84 W-100
610128 CHRY 44 FRONT 1981-84 W-200
610132 GM 60 FRONT 1981 K-30
610134 JEEP 30 FRONT 1981 IFS - EAGLE - DISCONNECT
610135 CHRY 60 FRONT 1981-85 D-600 & D-700
610136 JEEP 30 FRONT 1981 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610139 JEEP 44 FRONT 1981-85 J10, J20, WIDETRACK CHEROKEE
610140 JEEP 44 FRONT 1981-85 WAGONEER / CHEROKEE
610146 FORD 44 FRONT 1981 F-250 & F-350 HD
610147 FORD 50 FRONT 19818-82 F-250 & F-350 (SNOW FIGHTER)
610152 JEEP 30 FRONT 1982-82 1/2 IFS - EAGLE - NON DISCONNECT
610153 JEEP 30 FRONT 1982-82 1/2 IFS - EAGLE - DISCONNECT
610154 JEEP 30 FRONT 1981 1/2 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
610156 JEEP 30 FRONT 1982-83 CJ5 - EXTERNAL TYPE WHEEL END
610157 JEEP 44 FRONT 1982-84 WAGONEER, CHEROKEE DISCONNECT STD TRACK
610158 JEEP 44 FRONT 1982-84 J10, J20, WIDE TRACK CHEROKEE
610159 GM 60 FRONT 1982-87 K-30
610160 CHRY 44 FRONT 1985-89 D-600 (EXPORT)
610164 JEEP 30 FRONT 1982-87 CJ7/CJ8 - EXTERNAL TYPE WHEEL END
610166 FORD 44 FRONT 1981 1/2-82 F-150 SNOW PLOW
610167 FORD 44 FRONT 1983 F-150 SNOW PLOW
610168 FORD 44 FRONT 1983 BRONCO & F-150
610169 FORD 44 FRONT 1983 F-250 & F-350 HD
610170 FORD 50 FRONT 1983 F-350
610171 FORD 28 FRONT 1983-84 RANGER
610172 JEEP 30 FRONT 1984 XJ DISCONNECT, CV
610173 JEEP 30 FRONT 1983-84 IFS - EAGLE - NON-DISCONNECT
610174 JEEP 30 FRONT 1983-84 IFS - EAGLE - DISCONNECT
610175 JEEP 30 FRONT 1984-87 XJ DISCONNECT, CARDAN
610177 FORD 44 FRONT 1984 F-150 SNOW PLOW
610178 FORD 44 FRONT 1984 BRONCO & F-150
610179 FORD 44 FRONT 1984 F-250 & F-350 HD
610180 FORD 50 FRONT 1984 F-250 & F-350 (SNOW FIGHTER)
610182 JEEP 30 FRONT 1984-85 XJ DISCONNECT, CARDAN, SYSTEM SENTRY
610183 JEEP 30 FRONT 1985-87 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
610185 FORD 44 FRONT 1981-82 BRONCO II & F-150
610197 FORD 44 FRONT 1984 1/2-85 F-150 SNOW PLOW
610198 FORD 44 FRONT 1984 1/2-85 BRONCO&F-150
610199 FORD 44 FRONT 1984 1/2-85 F-250
610200 FORD 50 FRONT 1984 1/2 F-250 & F-350 (SNOW FIGHTER)
610201 GM 60 FRONT 1984-88 CUCV
610202 GM 60 FRONT 1984-85 K-30
610206 JEEP 30 FRONT 1985 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
610216 CHRY 44 FRONT 1985-86 D-500 & D-800
610217 CHRY 44 FRONT 1985-86 D-600
610220 FORD 60 FRONT 1985 F-350
610221 JEEP 30 FRONT 1985 XJ NON-DISCONNECT, CV, SYSTEM SENTRY - LIVE SPINDLE WHEEL END
610222 JEEP 30 FRONT 1985-86 XJ NON-DISCONNECT, CV - LIVE SPINDLE WHEEL END
610223 FORD 28 FRONT 1984 1/2-85 RANGER/BRONCO II
610227 JEEP 44 FRONT 1985 GRAND WAGONEER
610228 JEEP 44 FRONT 1985 4X2, MILITARY - DEAD FRONT
610229 FORD 44 FRONT 1985 F-250
610230 FORD 50 FRONT 1985 F-250 & F-350 (SNOW FIGHTER)
610231 FORD 44 FRONT 1985 F-250 & F-350 HD
610232 FORD 50 FRONT 1985 1/2 F-350
610234 JEEP 30 FRONT 1985-86 XJ 4X2, SYSTEM SENTRY (DEAD FRONT)
610235 JEEP 30 FRONT 1985-87 1/2 IFS - EAGLE - NON-DISCONNECT - CV
610236 CHRY 60 FRONT 1985-88 D-600 & D-700
610237 JEEP 30 FRONT 1985 XJ 4X2, SYSTEM SENTRY (DEAD FRONT)
610241 FORD 44 FRONT 1985 1/2 BRONCO & F-150
610242 FORD 44 FRONT 1985 1/2 F-150 SNOW PLOW
610243 FORD 44 FRONT 1985 1/2 F-250
610244 JEEP 30 FRONT 1986 CJ7, LH STEERING, H/L - EXTERNAL TYPE WHEEL END
610246 JEEP 44 FRONT 1986 J10 PICKUP
610247 JEEP 44 FRONT 1986 GRAND WAGONEER
610248 JEEP 44 FRONT 1986 J20
610249 FORD 28 FRONT 1986-87 RANGER/BRONCO II
610254 FORD 50 FRONT 1986-87 F-250 & F-350 (SNOW FIGHTER)
610255 FORD 60 FRONT 1986-88 F-350 MONOBEAM DRW
610256 JEEP 30 FRONT 1986-89 XJ 4X2 (DEAD FRONT)
610257 CHRY 44 FRONT 1986 1/2-87 1/2 D-500 & D-800
610258 CHRY 44 FRONT 1986-87 1/2 D-600
610259 JEEP 30 FRONT 1986 YJ DISCONNECT
610261 FORD 44 FRONT 1986 BRONCO & F-150
610262 FORD 44 FRONT 1986 BRONCO & F-150
610263 FORD 44 FRONT 1986 F-150 SNOW PLOW
610264 FORD 44 FRONT 1986-87 F-250
610265 CHRY 61 FRONT 1987-88 D-600 & D-700
610266 FORD 44 FRONT 1987-88 F-150 SNOW PLOW
610267 FORD 44 FRONT 1987-88 BRONCO & F-150
610268 FORD 44 FRONT 1987-88 BRONCO & F-150
610269 JEEP 30 FRONT 1986 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610270 CHRY 44 FRONT 1992-93 1/2 D-600 & D-800
610271 CHRY 44 FRONT 1992-93 1/2 D-600
610277 CHRY 44 FRONT 1988-88 1/2 D-500 & D-800
610278 CHRY 44 FRONT 1988-88 1/2 D-600
610279 JEEP 30 FRONT 1987 1/2-88 XJ DISCONNECT
610280 JEEP 30 FRONT 1987 1/2-88 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610281 JEEP 30 FRONT 1987-88 YJ DISCONNECT
610282 JEEP 30 FRONT 1987-88 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610283 JEEP 44 FRONT 1987-88 GRAND WAGONEER
610284 JEEP 44 FRONT 1987-87 1/2 J10
610285 JEEP 44 FRONT 1987-87 1/2 J20
610294 JEEP 30 FRONT 1987 1/2-88 XJ NON-DISCONNECT, ABS, ANTI SKID - LIVE SPINDLE WHEEL END
610295 GM 60 FRONT 1988-91 1/2 V-30
610297 JEEP 30 FRONT 1988 XJ DISCONNECT, VALEO EXPORT
610298 FORD 28 FRONT 1987 1/2 RANGER/BRONCO II
610300 FORD 35 FRONT 1990 RANGER/BRONCO II
610303 FORD 28 FRONT 1990-92 AEROSTAR
610304 FORD 50 FRONT 1988-88 1/2 F-250 & F-350 (SNOW FIGHTER)
610305 FORD 60 FRONT 1988 F-350 MONOBEAM SRW
610306 FORD 44 FRONT 1988 F-250
610307 FORD 28 FRONT 1988-89 RANGER/BRONCO II
610309 FORD 44 FRONT 1988 1/2 F-150 SNOW PLOW, BRONCO
610310 FORD 44 FRONT 1988 1/2-92 BRONCO & F-150
610311 FORD 44 FRONT 1988 1/2-91 BRONCO & F-150
610312 FORD 50 FRONT 1989-92 1/2 F-250 & F-350 (SNOW FIGHTER)
610313 FORD 60 FRONT 1988 1/2-91 1/2 F-350 MONOBEAM SRW
610316 JEEP 30 FRONT 1992 1/2-93 1/2 XJ 4X2 (DEAD FRONT)
610317 JEEP 30 FRONT 1990-90 1/2 XJ DISCONNECT
610318 JEEP 30 FRONT 1990-91 1/2 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610319 JEEP 30 FRONT 1990-90 1/2 YJ DISCONNECT
610320 JEEP 30 FRONT 1990-91 1/2 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610321 JEEP 30 FRONT 1988 1/2-89 XJ DISCONNECT
610322 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610323 JEEP 30 FRONT 1988 1/2-89 YJ DISCONNECT
610324 JEEP 30 FRONT 1988 1/2-89 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610325 JEEP 44 FRONT 1988 1/2-92 GRAND WAGONEER
610327 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT, ABS, ANTISKID - LIVE SPINDLE WHEEL END
610328 JEEP 30 FRONT 1988 1/2-89 XJ DISCONNECT, VALEO EXPORT
610329 CHRY 44 FRONT 1988-88 1/2 D-500 & D-800
610331 CHRY 44 FRONT 1989-90 D-600
610332 CHRY 60 FRONT 1989 D-600 & D-700
610333 CHRY 61 FRONT 1989 D-600 & D-700
610334 JEEP 30 FRONT 1988 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
610335 FORD 44 FRONT 1988 1/2-92 BRONCO & F-150
610336 JEEP 30 FRONT 1990-91 1/2 XJ NON-DISCONNECT, ABS - LIVE SPINDLE
610337 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
610339 JEEP 30 FRONT 1990-90 1/2 XJ DISCONNECT, VALEO EXPORT
610340 JEEP 30 FRONT 1990-90 1/2 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
610341 CHRY 60 FRONT 1989-90 D-600
610342 CHRY 61 FRONT 1989 D-600 & D-700
610346 JEEP 30 FRONT 1992 1/2-93 ZJ ABS, CV JOINT
610348 JEEP 30 FRONT 1992-93 1/2 XJ 4X2 (DEAD FRONT), ABS
610351 JEEP 30 FRONT 1990 1/2-91 1/2 XJ 4X2 (DEAD FRONT)
610355 CHRY 44 FRONT 1990-91 1/2 D-500 & D-800
610356 CHRY 44 FRONT 1991-91 1/2 D-600
610357 CHRY 60 FRONT 1991-91 1/2 D-600
610358 CHRY 61 FRONT 1991-92 D-600 & D-700
610360 CHRY 44 FRONT 1991-91 1/2 D-600
610361 JEEP 30 FRONT 1991-91 1/2 XJ DISCONNECT
610362 JEEP 30 FRONT 1991-91 1/2 YJ DISCONNECT
610363 JEEP 30 FRONT 1991 XJ DISCONNECT
610365 FORD 35 FRONT 1990 1/2-92 1/2 RANGER/BRONCO II
610366 FORD 35 FRONT 1990 1/2-92 1/2 EXPLORER
610367 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
610369 FORD 28 FRONT 1992 1/2 AEROSTAR
610371 FORD 60 FRONT 1992 F-350 (USES SOCKET ASSY INSTEAD OF KING PIN ASSY)
610372 JEEP 30 FRONT 1991 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
610373 JEEP 30 FRONT 1991 XJ NON-DISCONNECT
610374 JEEP 30 FRONT 1991 XJ NON-DISCONNECT, ABS
610375 JEEP 30 FRONT 1991 XJ 4X2 (DEAD FRONT)
610377 JEEP 30 FRONT 1992 1/2-93 ZJ ABS
610379 JEEP 30 FRONT 1992-93 1/2 XJ NON-DISCONNECT, ABS
610381 JEEP 30 FRONT 1993-93 1/2 YJ DOSCONNECT ABS
610391 JEEP 30 FRONT 1992-93 1/2 XJ NON-DISCONNECT
610392 JEEP 30 FRONT 1992-93 1/2 YJ NON-DISCONNECT
610393 JEEP 30 FRONT 1992-93 1/2 YJ DISCONNECT
610398 CHRY 60 FRONT 1992 D-600
610400 JEEP 30 FRONT 1993 ZJ (DEAD FRONT), ABS
610401 JEEP 30 FRONT 1991 1/2 XJ DISCONNECT
610402 JEEP 30 FRONT 1991 1/2 XJ NON-DISCONNECT
610403 JEEP 30 FRONT 1991 1/2 XJ NON-DISCONNECT, ABS
610404 JEEP 30 FRONT 1991 1/2-92 1/2 XJ 4X2 (DEAD FRONT)
610405 CHRY 60 FRONT 1993 D-600 & D-700
610406 CHRY 61 FRONT 1993-93 1/2 D-600 & D-700
610407 FORD 44 FRONT 1992 1/2 BRONCO & F-150
610408 FORD 44 FRONT 1992 1/2 BRONCO & F-150
610410 FORD 35 FRONT 1993-94 1/2 EXPLORER ABS
610411 FORD 44 FRONT 1993-93 1/2 BRONCO ABS
610414 FORD 44 FRONT 1993-93 1/2 BRONCO & F-150
610416 JEEP 30 FRONT 1993 XJ 4X2 (DEAD FRONT), ABS
610417 JEEP 30 FRONT 1993-93 1/2 XJ NON-DISCONNECT, ABS
610418 FORD 28 FRONT 1993-94 1/2 RANGER
610419 FORD 35 FRONT 1993-94 1/2 RANGER
610422 CHRY 44 FRONT 1994-94 1/2 W1500
610423 CHRY 44 FRONT 1994-94 1/2 W2500
610424 CHRY 44 FRONT 1994-94 1/2 W1500
610425 CHRY 44 FRONT 1994-94 1/2 W2500
610426 CHRY 60 FRONT 1994-94 1/2 W2500 HD
610428 CHRY 60 FRONT 1994-94 1/2 W3500
610430 CHRY 60 FRONT 1992-92 1/2 D-600 & D-700
610431 CHRY 61 FRONT 1992-92 1/2 D-600 & D-700
610432 FORD 60 FRONT 1993-93 1/2 F-350
610436 FORD 35 FRONT 1992 1/2 RANGER
610437 FORD 35 FRONT 1992 1/2 EXPLORER
610438 JEEP 30 FRONT 1993 ZJ ABS, CV JOINT
610439 FORD 50 FRONT 1993-94 F-250 & F-350 (SNOW FIGHTER)
610440 CHRY 60 FRONT 1994-94 1/2 W2500 HD
610443 FORD 44 FRONT 1994 BRONCO ABS
610444 FORD 44 FRONT 1994 BRONCO & F-150
610445 FORD 60 FRONT 1994 F-350
610446 FORD 44 FRONT 1995 BRONCO & F-150
610447 FORD 44 FRONT 1994 BRONCO ABS
610448 FORD 28 FRONT 1992 1/2-97 AEROSTAR
610449 JEEP 30 FRONT 1993 1/2 ZJ ABS
610450 JEEP 30 FRONT 1993 1/2 ZJ ABS
610451 JEEP 30 FRONT 1993 1/2 ZJ ABS
610452 JEEP 30 FRONT 1993 1/2 ZJ (DEAD FRONT), ABS
610459 FORD 50 FRONT 1995 F-250 & F-350 (SNOW FIGHTER)
610460 FORD 60 FRONT 1995 F-350
610461 JEEP 30 FRONT 1994-96 YJ DISCONNECT
610462 JEEP 30 FRONT 1994-96 YJ DISCONNECT
610463 JEEP 30 FRONT 1994-96 YJ NON-DISCONNECT
610464 JEEP 30 FRONT 1994 YJ DISCONNECT
610465 JEEP 30 FRONT 1994 ZJ (DEAD FRONT), ABS
610466 JEEP 30 FRONT 1994 XJ NON-DISCONNECT
610467 JEEP 30 FRONT 1994 XJ NON-DISCONNECT
610473 JEEP 30 FRONT 1994-96 ZJ ABS
610474 JEEP 30 FRONT 1994-94 1/2 ZJ ABS
610475 JEEP 30 FRONT 1994-97 ZJ (DEAD FRONT), ABS
610476 FORD 35 FRONT 1995 EXPLORER - DISCONNECT
610478 JEEP 30 FRONT 1994-96 ZJ ABS
610483 FORD 35 FRONT 1995-97 1/2 RANGER ABS
610484 FORD 28 FRONT 1995-97 1/2 RANGER ABS
610489 JEEP 30 FRONT 1997 TJ RHD, NON ABS (NEW MODEL NUMBER 181)
610500 JEEP 30 FRONT 1994 1/2-96 XJ 4X2 (DEAD FRONT)
610501 JEEP 30 FRONT 1994 1/2-97 XJ 4X2 (DEAD FRONT), ABS
610502 JEEP 30 FRONT 1994 1/2-97 XJ NON-DISCONNECT
610503 JEEP 30 FRONT 1994 1/2-97 XJ NON-DISCONNECT, ABS
610504 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
610505 JEEP 30 FRONT 1994 1/2-97 XJ RHD, ABS (NEW MODEL NUMBER 181)
610506 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
610507 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
610512 CHRY 44 FRONT 1995-96 1/2 W1500
610513 CHRY 44 FRONT 1995-96 1/2 W2500
610514 CHRY 44 FRONT 1995 W1500
610515 CHRY 44 FRONT 1995 W2500
610517 CHRY 60 FRONT 1995-96 W3500
610518 CHRY 60 FRONT 1995-96 W2500 HD
610528 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, ABS
610532 CHRY 60 FRONT 1995-96 AIR FORCE TOW VEHICLE NON-ABS
610537 CHRY 44 FRONT 1995-95 1/2 W1500
610538 CHRY 44 FRONT 1995-95 1/2 W2500
610539 CHRY 60 FRONT 1995-95 1/2 W2500 HD
610540 CHRY 60 FRONT 1995-95 1/2 W3500
610556 FORD 35 FRONT 1998 EXPLORER - NON DISCONNECT - CV
610557 JEEP 30 FRONT 1995 1/2-97 XJ RHD, NON ABS (NEW MODEL NUMBER 181)
610558 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, ABS
610572 JEEP 30 FRONT 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 181)
610573 JEEP 30 FRONT 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 181)
610576 CHRY 35 FRONT 1997-99 DAKOTA
610581 FORD 35 FRONT 1995-96 EXPLORER - DISCONNECT - CV
610582 FORD 35 FRONT 1995-96 EXPLORER - DISCONNECT
610585 FORD 35 FRONT 1996 EXPLORER - NON DISCONNECT - CV
610586 FORD 35 FRONT 1996 EXPLORER - NON DISCONNECT
610602 CHRY 44 FRONT 1996 W1500
610603 CHRY 44 FRONT 1996 W2500
610604 CHRY 60 FRONT 1996 W2500 HD
610605 CHRY 60 FRONT 1996 W3500
610607 FORD 44 FRONT 1996 1/2 BRONCO & F-150
610608 FORD 44 FRONT 1996 1/2 BRONCO ABS
610609 FORD 50 FRONT 1996 1/2-97 F-250 & F-350 (SNOW FIGHTER)
610610 FORD 60 FRONT 1996 1/2-97 F-350
610612 CHRY 44 FRONT 1996 W1500
610613 CHRY 44 FRONT 1996 W2500
610614 CHRY 44 FRONT 1996 1/2 W1500
610615 CHRY 44 FRONT 1996 1/2 W2500
610616 CHRY 60 FRONT 1996 1/2 W2500 HD
610617 CHRY 60 FRONT 1996 1/2 W2500 HD
610618 CHRY 60 FRONT 1996 1/2 W3500
610619 CHRY 60 FRONT 1996 1/2 W3500
610622 CHRY 60 FRONT 1996 1/2 AIR FORCE TOW VEHICLE NON-ABS
610629 JEEP 30 FRONT 1997 TJ ABS (NEW MODEL NUMBER 181)
610630 JEEP 30 FRONT 1997 TJ
610631 CHRY 44 FRONT 1997-97 1/2 W1500
610632 CHRY 44 FRONT 1997-97 1/2 W2500
610633 CHRY 44 FRONT 1997-97 1/2 W1500
610634 CHRY 44 FRONT 1997-97 1/2 W2500
610635 CHRY 60 FRONT 1997 W2500 HD
610636 CHRY 60 FRONT 1997 W2500 HD
610637 CHRY 60 FRONT 1997 W3500
610638 CHRY 60 FRONT 1997 W3500
610642 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT - CV
610643 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT
610644 FORD 35 FRONT 1997 1/2 EXPLORER - NON-DISCONNECT - CV
610645 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT
610652 FORD 35 FRONT 1997-97 1/2 RANGER
610653 FORD 28 FRONT 1997 RANGER NON ABS
610654 FORD 50 FRONT 1998 1/2-99 F-250/350 SRW ABS
610659 FORD 50 FRONT 1998 1/2-99 F-250/350 SRW NON-ABS
610663 JEEP 30 FRONT 1997 ZJ ABS (NEW MODEL NUMBER 181)
610664 JEEP 30 FRONT 1997 ZJ ABS (NEW MODEL NUMBER 181)
610665 JEEP 30 FRONT 1997 ZJ (DEAD FRONT), ABS (NEW MODEL NUMBER 181)
610714 CHRY 60 FRONT 1997 1/2 AIR FORCE TOW VEHICLE NON-ABS
610715 CHRY 44 FRONT 1998-98 1/2 W1500
610717 CHRY 44 FRONT 1998-98 1/2 W1500
610719 CHRY 60 FRONT 1998-98 1/2 W2500 HD
610720 CHRY 60 FRONT 1998-98 1/2 W3500
610722 CHRY 60 FRONT 1998-98 1/2 W3500
610723 CHRY 60 FRONT 1998-98 1/2 W3500
610729 CHRY 60 FRONT 1997 1/2 W3500
610730 CHRY 60 FRONT 1997 1/2 W3500
610738 CHRY 60 FRONT 1997 1/2 W200 HD
610739 CHRY 60 FRONT 1997 1/2 W2500 HD
610740 FORD 50 FRONT 1997 1/2-98 F-250 & F-350 (SNOW FIGHTER)
610741 FORD 60 FRONT 1997 1/2-98 F-350
610774 FORD 35 FRONT 1999 EXPLORER - NON-DISCONNECT - CV
610892 FORD 50 FRONT 1999 1/2-2000 F-250/350 SRW NON-ABS
610893 FORD 50 FRONT 1999 1/2-2000 F-250/350 SRW ABS
I did not see for a 74 to 76 cj-5 44 rear flange axel on the list
What will you find in a 73 J10 pickup?
yeah that is just a partial list, i will do some searching for a full list :idea:
Quote:
Originally Posted by W.T.Sumner
'73 J-2500 frnt 63.5" rr 63.8"
'73 all other J trucks frnt 63.9" rr 64.4"
In 1970 and 1971 the CJs came with offset 30 spline flanged Dana 44s. Before 1970 they were tapered 19 spline axles.
I have one of the 30 spline offset flanged Dana 44s. :mrgreen: 8)
Erik
That is some good f/n info!
Add Jeep '61 FC 170 DRW to '68 Gladiator DRW D70 rr 66"
I'm still trying to get the width of the front D44 on those applications.
Hmnnn!
Its a bit early, but my '70 J3000 has Dana axle codes of
Front 44F:602577-3
Rear 70:602853-1
In my dana book the closest i can get to the front axle code is for the 44F 602577-1,-3,-7 allegedly in only J10,J20 6 cylinder of 1967.
dana Book reference XF-44J of June 78, Index 094
This is confusing everbody whom I try to get diff parts from :lo1l: .
Maybe its a "wierdo".
Additionally nobody will believe me that the offset on the Dana 70 (rear) is 1.12 inches. All say .5 inches.
Any thoughts help or ponderings appreciated.
