Soooooooooooooo.....any new updates?
back to the build. I guess last time we worked on this was around Jan... ha ha... nothing to much tonight... just started to change the bearings in the third member...
http://img.photobucket.com/albums/v9...s/DSCF2308.jpg
http://img.photobucket.com/albums/v9...s/DSCF2310.jpg
the tape that they used for the power coating was a sum a biatch to remove...
http://img.photobucket.com/albums/v9...s/DSCF2313.jpg
1 year after we purchased the press, we finally get to use it.
http://img.photobucket.com/albums/v9...s/DSCF2315.jpg
we didn't have any brass punches and instead ofusing a steel punch, we placed the old bearings in the new race then placed a pipe "no poop pipe must be used" and macked her down... worked great.
http://img.photobucket.com/albums/v9...s/DSCF2317.jpg
same with the pinion side.
http://img.photobucket.com/albums/v9...s/DSCF2318.jpg
can't forget about the shop dog... Mr. Wrinkles...
http://img.photobucket.com/albums/v9...s/DSCF2319.jpg
finalizing the gearz...
http://img.photobucket.com/albums/v9...s/DSCF2324.jpg
not done, but we tested it anyways...
http://img.photobucket.com/albums/v9...s/DSCF2326.jpg
http://img.photobucket.com/albums/v9...s/DSCF2327.jpg
http://img.photobucket.com/albums/v9...s/DSCF2328.jpg
wtf is this? as we were checking the pattern i noticed this. It looks like the metal is just rotting from the inside out. so should i stop and replace the ring gear?
http://img.photobucket.com/albums/v9...s/DSCF2325.jpg
That last picture looks like the carrier, not the ring gear??
Just a typical porous casting on the carrier. It won't hurt a thing to use it.
carrier ring gear... what evar... 8)Quote:
Originally Posted by Mudrat
for right now we just want the car to be a roller, since the gearz are 2.76's we'll change it to 3.73 i hope... not to sure if thier is a carrier break or not, but if anything we'll replace and leave it as a spare.
:t:
VERY Sweeeeeeeeeeet :t:
Hey, this isn't England you know :mrgreen:
http://img.photobucket.com/albums/v9...r020Medium.jpg
your the only one to say this... forst thing Cat said to me "i miss Japan"Quote:
Originally Posted by rollbar
ha ha...
now for tonight's round of pics...
as of right now i need to make this car a roller... i need to get the axles in and then put her on rollers... so i can put the pontoon in and start working on it... Summers coming and the lakes are calling... of course i have a couple thousand pics of everything, but i can't find a pic up close of the pontoon...
here it is with all of are other stuff "junk"
http://img.photobucket.com/albums/v9...A/DSCF2251.jpg
back to the axle, little painting...
http://img.photobucket.com/albums/v9...s/DSCF2331.jpg
http://img.photobucket.com/albums/v9...s/DSCF2330.jpg
of course it wasn't drying fast enough, so...
http://img.photobucket.com/albums/v9...s/DSCF2335.jpg
new seal...
http://img.photobucket.com/albums/v9...s/DSCF2332.jpg
http://img.photobucket.com/albums/v9...s/DSCF2334.jpg
of course since this is just going to be a roller... we took the breaks off and in order to fit the axles we had to make some "shop shims"
http://img.photobucket.com/albums/v9...s/DSCF2342.jpg
http://img.photobucket.com/albums/v9...s/DSCF2344.jpg
good for a roller...
http://img.photobucket.com/albums/v9...s/DSCF2345.jpg
also forgot to add some old pics of the car from the blasting work about 2 months ago...
http://img.photobucket.com/albums/v9...ris/top023.jpg
http://img.photobucket.com/albums/v9...ris/top022.jpg
http://img.photobucket.com/albums/v9...ris/top011.jpg
http://img.photobucket.com/albums/v9...ris/top010.jpg
http://img.photobucket.com/albums/v9...ris/top008.jpg
http://img.photobucket.com/albums/v9...ris/top007.jpg
Man, you sure are making some great progress! As always - if you need an extra pair of hands, just let me know!!
I am eyeballing this thread Frankie!
Frank - what's the plan for the old Willy's you got out there? Happen to have a 54 or a 55?
