When i do the mp3000 test i get the up and down flashes but each one only flashes 3 times instead of the 5.
wait I must have skipped that part = P or never counted anything. :crazyeyes:
HEre is the test procedures mine does this but flashes 3 times instead of 5.
Activate the recessed TEST Button on the front panel of the MP3000-DTHC or your unit with the DTHC module installed and connected. The TEST LED should start flashing.The unit goes into a test sequence where the TIP VOLTS DRO is set to 100 and the UP screen LED flashes 5 times. Then the TIP VOLTS DRO is set to 150 and the DOWN LED flashes 5 times. This test sequence repeats until you hit the Test Button again and the TEST LED stops flashing.
AIf the test does not show the above results the most probable cause is the serial communications is not working between the PC and the MP3000. Make sure you have the right port selected. If you were sent a special serial cable with the RS232 buffer module (see photo) make sure it is installed correctly.
WOW got her cuttin today! My first cut was with the THC on(brass nuckles) cut ipm was to slow (85 ipm) but the THC isnt dialed in so it was way out of wack. The second cut(alien head) i turned off the THC and cut at 110 imp and it did great hardly no dross. I used 1/8 material.
http://i20.photobucket.com/albums/b2...e/photo135.jpg
http://i20.photobucket.com/albums/b2...e/photo137.jpg
http://i20.photobucket.com/albums/b2...e/photo138.jpg
http://i20.photobucket.com/albums/b2...e/photo140.jpg
http://i20.photobucket.com/albums/b2...e/photo139.jpg
did you get a massive bevel on one side of that alien,
No no bevel. Here is a small piece i cut to see how it would do on close cuts it cleaned up good and i painted it.
http://i20.photobucket.com/albums/b2...e/photo141.jpg
I just want space to put one!!! My shop is all wood and filled with a Jeep right now :-(
'Rat
Push that ole jeep outside someone will haul it off. LOL
