Star-Lab CNC Maintenance
Linear rails should be greased every 50 hours on the Y axis and every 200 hours on the Z axis. Ballscrew every 200 hours.
Specific grease fitting for Y axis linear way trucks
http://www.toolsource.com/lube-link-...-p-144782.html
X axis rails should be wiped with cloth damp with WD40 twice weekly
For those of you who are Amazon/Prime addicts, like myself...
https://www.amazon.com/dp/B003V5JICW..._nu2QwbY1GAKEP
What type of grease should we be using?
Just Standard grease. Do not use any high end grease as some might have a PH that is not neutral.
The Grease that my table came with is red, would Lucas Red & Tacky #2 work, or something more robust like either of these 2.... https://www.amazon.com/Red-Line-8040.../dp/B000CPAEJA or https://www.amazon.com/DuPont-Teflon...nthetic+grease
Just want to get something close or compatible with what was already used!
Thanks!
No special grease needed.
