Thanks Fuzz.
May try that in the future.
Thanks Fuzz.
sweet jeep. mongo likes the 401 under the yj's hood
Sweet 401 jeep..!!
DAMN and his Lighting (page 3) has more HP & Torq than my Hemi!!! :shock: (stock anyway :wink: )
HOW DID U WIRE UP THE IGNITION I have a 401 in my 88yj with np435 and np208combo out of a ford i just cant figure out how to wire it up without a push botton there is a goofy purple wire on the ignition that i think gose to a nutral safty switch or needs to be grounded
AND DAM NICE JEEP :lo1l: :lo1l:
shawnsc25
Do you have or did you have an Auto tranny in it? If so yes, the purple probably is the neutral safety sw wire. If you look at the stock starter solinoid there is a 3rd post terminal for the neutral safety sw. There are 2 kinds of Jeep starter relays, with and without the post for STD and Auto trannies. On my YJ I ran it and grounded it at the (STD) relay. But it's there if I want to use a 3 point relay (or put the STD relay in and install a cutout switch for a 'theft protection gizmo' #-o )
ihad the ax5 in it and what is std my dad seems to think that because it had the option of the auto that they threw in a nutral safety switch anyway
Went back to my original post. Easier I think.
Updated running gear; rear D60, 35 spline, 4:88s, 37" tires, 6" RC SUA kit, 10.7" rear discs, .... Replacing front axle next.
Not sure how to attach pics. Will try the car domain website again.
http://www.cardomain.com/ride/358741/2
PS: Oh ya, new Bulltear 8 qt pan. Still holding 40 psi idle, hot oil pressure. Your midplate and remote filter also. Good stuff, thanks again.
PPS: Matt, those 2 rear bolts on the pan were a royal PITA to tighten, no room to sneak an extension through the gap with the trans cover or swivel socket with the AX15...any secrets? Did the 1/16th turn at a time trick w/ box wrench.
Noted, will make changes!
Really not "complaining."
Just looking to see if there was some alternative method I have not thought of.
