Hear anything about possible problems yet?
Matt
Sent you an email with a screen shot. Didn't see the Intel management on there.
Are yall out of the shop this week?
Absolutely here but we had two days with Hypertherm. That set us back a little. You may need to meter the incoming power on your PC while your cutting to see where your power surge is coming from. This will tell us if it is the line to the PC. It is definitely NOT the PC. We ruled that out several times by sending a different PC and running yours. It is not the HUB you tried a working hub and yours also works fine. The only component that could be replaced now would be the Controller. But before we even attempt that we need to know that the PC does not see a line surge.
Back in town Matt so let me know when the box sends out.
Will do, should be Monday/tuesday
Still no boxes yet?
One has been prepped for you. But I want you to do one more thing. Go to your power settings in windows and default everything. Try your cutting again.
Only think that seemed to change on the power settings was the screen screen shut off time and the sleep mode time. Still shut down. Even tried turning the display to recommend setting instead of high performance. Is there another power setting somewhere I may have missed?
Ok Walter the last piece of this strange puzzle will be there on Wednesday. Let us know how it works out please. You may need to call in for tuning values..ect.
