**NEW BTA BULLET 2x2 and 2x3 modular plasma systems**
Our new Bullet CNC Plasma table is screaming fast and smooth. Check out these specs!!
Rapid capability of 1500ipm easily modified in software
Portable
Dual X drive motors
Single Y drive motor
Full Z axis with 5"s of travel with Z touch and cut micro switch
All aluminum gantry parts are CNC machined
Hardened V rail with wipers and oil wicking billet wheel covers
2"x2" boxed steel frame
Capable of horizontal and vertical cutting
Full support and online support forum
Comes crated and complete!
Everything you need to make CNC cut parts minus PC and plasma cutter
2x2 $2800
3x2 $3000
http://i2.photobucket.com/albums/y29...BTAbullet2.jpg
What makes this table so fast and accurate is that it uses the latest motion control hardware capable of morphing from micro step to full step without delay and with supreme accuracy. This means we have a very very fast rapid move and equally as fast feed rates. We do ot use limit switches on our tables due to the possible installation error or switch error that may cause crash damage to your machine. We instead use a gear rack tailored to the travel of the machine so if you over travel the gear comes off the rack and the machine slides top a stop against our limit travels with zero damage.
