tell me what you want, chances are i have a bunch of them.
MC....moderator
MC....moderator
You asked... :roll:
Vent control module (non-A/C) 87 YJ
Tach for the 87
Drive shafts (you have the specs on those)
Diagram for the vent cables that go with the vent contol module,
That'll get the Jeep running
Also need a winch for the Dodge (behind the bumper) 12K + cap with roller fairlead.
Could use one for my 85 too :D
NP231 t-case :?: :?: :cry:
Yup, 231. Called Tom Woods today and got the tracking number. UPS said the kit will be here on the 8th. If we don't get rain next weekend, I'll be putting th SYE and rear shaft in. I need shafts for the front YJ and both shafts for the 85 CJ.
From an earlier post:
A) The front shaft for the 87 YJ (NP 231, 1" skid plate drop): running length is 41.375 cntr to cntr with about 8-9 degree angle, stock U-Joints weight on the wheels. The drive shaft is 38.25 & 41.25 (coll/extended)
B) I ordered the AdvAdapt 231 slip yoke eliminator kit today with a Tom Woods CV joint rear shaft (rear shaft has a 22 deg angle), it should be here by Fri/Sat they said. Should be a good weekend If I can play hookie from my chores
C) The 85 CJ (D300), front shaft running length is 33.75 after the M.O.R.E spring reverse install and your skid plate drop kit, the shaft is 32" short and 34.5 long so I'll need some length there. Angle is only 8-9 degrees.
D) Rear shaft...I dunno maybe a little longer too? Running length is 22.25 C-t-C, but the shaft is 20.5 short and 23.375 long, with a 22 deg angle. I'm sure I'll need more than 1 1/8 inches of drop .
I don't know the full droop on the springs, where the Jeeps are now It would take a bit to jack'm that high and measure.
Comments anyone? Sugestions? Like I said, I've never tried to figure this out before - how much slide do I need?
If you provided them with the running length when you ordered the shaft, it should be just right.
I may now need a NP231 t-case. :cry: Would you have that :?:Quote:
Th400 - to - Dana 20 Adaptor?
just got rid of a ZJ 231(big chain version)
I do have a th400- dana 20 ...would need a week to pull it out though and would need $100 for the adaptor
I'm looking for a limited slip diff for a D30 (small carrier-3:55 and down), something like a power lock or tru trac.
kid let me do some checking
