Doesn't matter where you mount the shocks, as long as they don't bottom under compression, or over extend.
Maybe a lift kit or extended bump stops to stop the diff from hitting?
Glad I was able to help with the problem. That what places like this are for.
That would work but the proper thing is to move the motor up.
The PO put a scout 800 body on the wagoneer drivetrain after being tboned in the wagoneer. He mounted the motor lower than normal because he didnt want to modify the firewall.....I on the otherhand have no problem cutting the firewall to make it all fit properly. Just going to take some time before I get that far.
