Warnings about oil pump gears
Ok guys a little warning here about replacing your oil pump gears with new ones.
1. Make sure they dont have dings and dents on the gear face or edge.
2. Do not install gears if they have burrs on top or bottom.
To fix this problem we have taken stock replacement gears and refinished them by way of breaking sharp and burred edges and lapping the gear faces and edges.
If you install new gears thinking you are helping your oil pump, you may actually be damaging it. I have talked to alot of jeeps who say they replaced the oil pump gears and got good oil pressure and then experienced a pressure drop and never a return of peak pressure values.
In fact they are scoring their oil pumps and damaging their gears. I make replacement oil pump sets with high or standard pressure and mine are totally gone over but you can buy a replacement set from many automotive stores, Just be carefull guys/gals, and keep those engines oiled
MC
