401 Jeep cam choice
Hey guys I have a question for you if could help with choosing camshaft for my Jeep.
I have a 1982 Jeep cj5 with AMC 401, 727 automatic transmission 4:56 gearing and 38" tires.
9,5 compression, head 090, edelbrock Performance manifold, 670 Holley truck avanger carb and 1 5/8 header.
I want to get more low end tourqe out of the engine what kind of camshaft should i choose?
http://f4x4.is/index.php?option=com_..._itemId=248035
Albert
My choice stands beetween 2 types of camshaft i´m not sure wich one to choose and what the difference beetween those 2 will be. So if somebody knows more about those types or has tried them out it would be great to get some tips. Those camshafts are
Lunati Voodoo
•Advertised Duration (Int/Exh): 262/268
•Duration @ .050 (Int/Exh): 220/226
•Gross Valve Lift (Int/Exh): .507/.527
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1600-5800
and
Comp XE262H
Valve Lift Int/Exh .493/.500
Duration Adv. Int/Exh 262/270
Duration @.050 Int/Exh 218/224
Or if somebody would reccoment to me some different type for my Jeep.
I´ve been building Jeep´s since 1976 but i´m not the best one with the motors so it would be great to get some tips
Albert
Have you tryed calling comp. or any other cam manufactor there very good at fuguring out the best cam for your aplication with your specs. you give them to meet your demands. Just a thought. :t:
I tried that and the silence at the other end pretty much answered the question. What he did finally suggest was wrong as he based it off a chevy cam with a smaller lifter diameter. I would suggest Straight Line Performance as he knows AMC motors very well. I run his product in my Mud Race CJ and have been very happy with it. Just my .02 cents worth.
I went with the Voodoo and am very happy. Numbers are here:
http://www.ifsja.org/forums/vb/showthread.php?t=121315
looks like you made the correct choice. nice dyno pulls.
Go with the voodoo and advance 2-4 degrees using your timing chain.
Thank you for the respondes
What do I gain by advancing 2-4 degrees using my time chain?
I bought Lunati voodoo cam 64502 262/268 507/527. I also bought forged pistons 9.5 compression, hp oil pump, cam bearings, rod bearing, main bearing, SFI balancer fit and more from bulltear.
Everything I have orderd from Bulltear is definetly high quality stuff and they really know what they are selling. I highly recomend them for AMC users.
Best regards, Albert
On second thought looking at the duration I dont think advance would be a good idea you would sputter out of power at 3000rpm. Install that camshaft strait up with no tricks done to the timing set.
