Quote:
In the first picture of the solenoid, disconnect both small red and blue wires turn the ignition switch to the run position test them for voltage the one with voltage connect to the coil plus, then turn the ign to the start position the other wire should have voltage only in the start position if thats the case connect that wire back on the solenoid , than the black wire that is disconnected in your picture connects to the opposite side of the solenoid that should be the ground wire , then you should be good to go.
