Huge CNC Plasma sale (Free CAD, nesting, upgrades) Through december 31, 2013
*Post up to get a quote
Bulltear is proud to announce through our suppliers both new and old a sale on CNC plasma gantry and complete machines with several key upgrades. These tables have been extremely popular with both seasoned operators and folks just starting in the CNC world.
http://bobcad.com/wp-content/uploads...cam-hobby2.png
http://bobcad.com/wp-content/uploads...6/bob-nest.png
1. The first upgrade is Bobcad Ver 25 Xpress with Nesting. That is right free nesting software for nesting your .dxf drawings or any drawing you make in Bobcad or any other CAD system. (A $1495.00 value!)
http://i2.photobucket.com/albums/y29...psc9dca42c.jpg
2. The second is completely on us and it is a dual rail setup on our gantry system capable of much much greater rigidity than we already have. This allows routing and very stable movements on gantry sizes up to 10' wide. The dual rails give us faster accel rates due to the very low friction rates associates with these types of precision rails found in machines $80,000 and up. (sorry for the teaser pic we will refine it shortly)
3. The third is free crating until the sale ends. Gantry kits get a pine box fit for a king and made to take serval hits from thermo-nuclear warheads and will resist biting zombies for days. Seriously the crates we build are made to keep your gantry kits in place and are made to be completely sealed out of a solid 2x4 frame. Tables are crated to hold all the components under the frame or shipped completely assembled ready to cut. (Full tables come with a PC preloaded with software)
4. Upgraded cable carrier with X2 sized openings for all the wires, cable protectors, router cables, plasma leads and air lines you want for your machine.
Current Sizes
4x4
5x5
4x8
4x10
4x12
5x8
5x10
5x12
6x8
6x10
6x12
8x10
8x12
For current customers that want to take advantage of the upgraded gantry (dual rail) please PM here or drop us a email or phone call @ Orderbulltear@yahoo.com or 1-855-433-3689 we have a gantry exchange program available.
For those that dont know already about these amazing machines here is a spec sheet
1. Each axis has a spring loaded wiper system to resist contaminants and dust
2. Ultra fine resolution at .0004
3. Accel and Deccel rates of 40 per second per second giving you crisp geometry
4. Rapid speeds of up to 1000 inches per minute
5. 1" diameter round linear rail for the Z axis with zero maintenance performance
6. Preloaded profile linear rails for X and Y axis with zero maintenance performance
7. Wide gear rack positioned out of harms way underneath the outer rail
8. Magnetic torch breakaway safety system (MAG-LOK)
9. Torch height control features
a. Corner lockout
b. Pierce delay
c. Tip volt adjustability
d. Tip volt reading adjustability and accuracy
10. 2 year warrantee on electronics
11. Arcitecture is made to avoid any and all crashes (you cannot overtravel our machines X axis or Y axis)
12. Operating system is simple and includes offsets
13. The ability to zero the machine anywhere in the travel
14. Generous 8" clearance from bottom of Z axis to top of the table
15. Ability to add 8" chuck tube cutter ($1400 option)
16. Full welded box steel frame and powdercoated for durability
17. Water pan with slats and drains
18. Hand controller
19. 1/2" thick steel feet with 3/4" levelling bolts
20. Hypertherm quick connects and will virtually support any plasma cutter
21. Torch mount fits .875-1.75" torch bodies (other mounts available)
22. Extra relays in the box ready to be controlled via the PC
23. Overheating protection, surge protection
24. Compatible with high density plasma cutters
Access to our support and instructional forums
1 year warrantee on all hardware and electronics
