First time cutting problems
Having some issues with my new set up after waiting a few months to get setup.
1) Sometime it will cut the first circle or line in the part and than on the next circle or line on the part it will stop in the middle of the program. I will hit run again and than it will finish out the part without cutting any thing. It has been pretty consistent with wanting to stop in the middle of the program and for me to hit run again 2-3 times to get it to finish. The torch is also been stopping and randomly cutting during this.
2) Some it will not fire at all and just be blowing air through the torch while its running the program.
3) After hitting reset and getting a solid green bar sometimes i can't toggle the torch using the key board. Will restart everything to get it to work
4) Sometimes when i turn on Bladerunner Mach 3 program I get the error below.
Wakeup Client doesn't reply
-Yes to retry
-No- to config
-Cancel to quit
5) Should the ground cable be attached to the table or work piece?
I'm sure theres a couple things I might be doing wrong so any help would be appreciated.
