Hard to say with the plasma cutter now giving an audible issue. A small air leak can sometimes sound like a crackle.
Tom wants me to rma the pwm. He thinks that's the reason my voltage is acting up. So I'll give that a try.
I got my new (used) dell gx620 pc. Have it optimized and ready to go. Cant cut with it until I get my pwm from candcnc though.
I will keep you updated
Finally got the new pwm in the mail. Everything seems to be working right. This is the first time I've been able to use thc. Happy happy happy.
GREAT!
Built a computer desk and a water tank for draining the table. Tank is 18" tall x 24" wide 48" long. Holds 87 gal. Works well. I have two 1-1/2" drains in the table that tee into a 2" strainer, and 2" plumbing to the tank. It takes very little air pressure to fill the table back up.
Attachment 398
Attachment 399
Built the tank using the table. Cut slits for bending and for welding the inner supports for the top. Worked good, but it obviously does add a bit more welding than using a brake.
Attachment 400
Attachment 401
Attachment 402
