a cam plug for AMC V8's whats going on!
After constant battering from AMC fans who are sick of cam walk at high RPM's but cant afford much we will be making a cam plug that will ensure a proper cam placement.
Made out of UHMW with twice the impact strength of acetate (delrin) these cam plugs will come with a cam bolt and instructions on how to set it up...simple bolt on really.
A Cam plug is a neccesary piece if you run a roller cam or your lifters arent holding the camshaft in place (Like my latest 401..roasted after 2hrs of zero oil pressure cause by cam walk. :!: ) You can do every possible mod to your engine to get the right oil to the right area but if that camshaft walks you ruin
your bearings
your cam gear and distributor gear
your oil pump cavity
score your cam and crank
More as we finish the prototypes
